OT Repairing vinyl floor?
>Just had a new sheet vinyl floor put in a rental house. Cleanup crew gouged it. I now have a flap about the size of a thumb nail. Anybody got any idea what type of glue to use? (I have CA) Got the installer looking for part of a bottole of "seam sealer", but not sure they will come through. TIA
Re: OT Repairing vinyl floor?
Joseph Mulherin
>Barry, If you have a pattern in the vinyl, cut a piece about 4" square, lay it over the gouge and tape in place. Be very sure to match any patterns in the original. Using a builders square lay it on top of the new vinyl and cut through BOTH vinyls to the floor. Lift out the old piece with a putty knife and clean up any residue. Apply the glue you are using, place the new patch in place( it will fit perfectly) and use a seam sealer to meld the pieces together. You will not ever be able to see where the gouge was after a couple months.
Go to DIYNetwork.com and find out their suggestions.
