Wobble Wobble OT Ceiling fan
Dustmaker Mike
>I just got done installing two new ceiling fans in my house. One spins round and round with out a bit of wobble. The other wobbles really bad at high not so bad on midrange and almost not at all on slow. So I know I have to balance it but how do I know which blade needs the extra weight added to it?
Re: Wobble Wobble OT Ceiling fan
Nat Robison
>Although I've never had to balance a fan myself, most come with instructions on how to do it and materials. I would check first that the boxes in the ceiling are rock solid.......either screwed a couple of times to a truss or a box that has the arms to attach between 2 trusses. Trying to hang a fan from a box that was originally put there only for a light might be the problem.
Jason Roehl in Mulberry, IN
>Start with trading blades around. You'll want to number/letter then with pencil on the top of the blade before you start so you can keep track. If that doesn't work, then you'll have to start either bending the brackets or adding weights. At that point, you're on your own...(wink, wink).
Jason
2nd that !
SteveM
>If the box and hanger are rock solid I've never had it wobble. I've fixed relation's wobbles by beefing up the same.
>Double check the box/hanger as suggested. A wobbling fan might giggle itself free after a while. Not a pretty sight.
Then try swapping the blades around.
The Fan companies sell a balancing kit. I had a neighbor that taped a quarter onto of one blade. He just guessed and put on different ones until it ran smoothly. Moved it around until he found the "sweet spot". About a year later, it flew off. This time he glued it.
Re: You might also check
Joanne Adler in Pt. Pleasant, PA
>to make sure none of the arms that hold the blades are bent. I had a fan in this house that was like that when I moved in. It wobbled terribly and made me feel as if I might be decapitated at any minute. I replaced the fan. No French Revolution in my house!
Joe Pack
>Assuming the mounting box is secure, you will need the little balancing kit usually included in the bag. Check the instructions with the fan...they typically tell you how to go about balancing.
If there are no instructions or balancing kit, grab a penny and some masking tape. Pick a blade. Tape the penny in the middle of the blade. Spin up the fan. Does the wobble get better or worse? Pick another blade. Move the penny to that blade. Better or worse? Repeat until you find the blade that best reduces the wobble. Now move the penny about 1/4 of the way from the end of that blade? Better or worse? If better, move on toward the end and repeat. If worse, move toward the motor end of the blade. You will eventually find the "sweet" spot where the fan pretty much evens out. Once you find that spot, try more or less weight...a dime, a nickel, two pennies...or use various size washers. When you are happy, replace the masking tape with a drop of super glue and you are ready to enjoy a wobble free breeze!
Thanks All
Dustmaker Mike
>I guess I have to climb into the attic and see the box. The house came with ceiling fan support built into each room. The other rooms don't have a problem just this one. If the box is indeed solid then I will play the penny game. Thanks
Real Men don't read instructions or need directions(-; Except the Grand kids helped unpack the fans and the instructions are no where to be found on this earth)-: Sort of like my GPS instructions on where to turn they are not directions
A.J. Hamler
How to fix wobbly ceiling fan
A.J. Hamler
>To fix a wobbling or shaking fan, the first thing to realize is that you may be spending a lot of time up near the ceiling. Don't attempt to correct a wobbly fan unless you have a good, stable ladder to work on. Although possible to fix on your own, the help of a second person is a huge asset. Here are the probable causes in the easiest and most likely order to check.
To begin, loose connections anywhere in the system can cause wobbling. Check all screws and bolts securing the blades to the irons and the irons to the motor. Check the ceiling mounting, down rods and the motor housing. There should be some amount of play in the entire system, but if any one component is loose, tighten it securely.
There are several causes for a wobbling or shaking ceiling fan, but the most likely cause is that the blades are misaligned. And the most likely cause of blade misalignment is that the mounting brackets -- called blade irons -- are bent. So how did the blades get out of alignment? Any number of ways. The weight of the blades over the years may have put more stress on one blade iron than the others. One or more of the irons may have been bent while cleaning or even during the original installation (this latter cause is very common). If the blades have ever been hit or bumped by hand, broom or any other object, it may have deflected one blade up or another blade down... or both. Finally, one of the irons may be cracked or broken.
Sometimes, it's easy enough to check alignment by slowly spinning the blades by hand and observing how they turn - a low or high blade is sometimes obvious. If not, have your helper hold a yardstick against the ceiling at the end tip of one of the blades. (You can also use a broom handle or any long pole or stick.) Note or mark where the blade tip meets the yardstick. Now turn the fan by hand till the next blade meets the yardstick -- is it at the same spot, or is it higher or lower? If it doesn't hit that same spot, congratulations: You've just determined that your blades are misaligned. With your helper holding the yardstick, straighten each of the misaligned blades in turn until all are exactly even with the mark on the yardstick. Straighten the blades by hold the fan motor securely with one hand to keep it steady, then gently lift or lower the blade to correct it. Do this very carefully, just a little bit at a time; overdo it, and you might snap the blade iron. When all the blades are at the same level, test the fan. This will most likely fix the problem.
Wobbling can also be cause by unbalanced or warped fan blades. If your blades are correctly aligned as per the above instructions, check each blade by sighting along its length. If the blade is bent or twisted, it's time to get a new set of blades. Be careful when removing the old blades and attaching the new ones that you don't bend the blade irons. If the blades are unwarped and aligned, it's possible that the blades aren't balanced. If that's the case, then a blade balancing kit may fix the problem. All fan manufacturers offer these kits, and you can find one at your local Home Depot. Follow the instructions for balancing that come with the kit.
And finally, it's possible that the motor is out-of-balance. Although this isn't likely - very few motors leave the factory out-of-balance - it can easily be checked by removing the blades and irons, and running the fan without them. If everything is secure and all screws and connections are tight, and the fan still wobbles or shakes, then the motor may be the problem. However, an out-of-balance motor is so uncommon, that it's best to do this test last.
Hope this helps.
A.J.
Re: easier than the penny
Kneale Brownson in sunny N. MI
>A small spring clip clipped to the leading edge of the blade. If you bought a Hunter, they usually include the clip in the fan kit, along with a self-adhesive weight to attach once the wobble is figured out. If you bought a Hunter and it doesn't include the kit, you can call them and they'll send you the wobble fix kit. Then follow Joe's procedure.
Marv
>Hi Mike,
My best advice is to go with A.J.,s instructions. Sounds like he's a bonified fan balancing kinda guy.
Here's something no one has mentioned....I instaled a fan that is suspended from a rod that is held in a ball joint that allows the fan to move around a bit. This type of mount is meant to be used on a sloping ceiling. With this in mind, a fan can be balanced even though it might not be solidly connected to the ceiling. However, it's always best to have the fan secured so it won't work it's way loose from it's mounts.
Have fun.
Marv
Lee Gordon
Maybe you should write for a fan magazine :-)
Lee Gordon
A.J. Hamler
I joined a fan club. That count?
A.J. Hamler
Lee Gordon
Only to 10, Mudhead.
Lee Gordon
Always new that.......
>Always knew that A.J was a good, well-balanced individual ;)
Happy Woodworking!
A.J. Hamler
This one goes to 11, Porgy
A.J. Hamler
