Re-finishing Question
Mike Turner
>I have a neighbor who has an oak dining room suite (table with 6 chairs) They are stained golden oak and finished (commercially) with lacquer.
She wants me to re-do them in black satin lacquer. I agree, it is a shame to cover the oak, but that's what she wants.
Here is my question.....How much of the existing lacquer finish do I need to remove before re-coating them with the black lacquer??
Can I soak the existing lacquer finish with lacquer thinner and scrub with fine steel wool or 3M scrub pad??? Or, do I need to go to a full strip of the existing finish and start my new black lacquer finish from there??
I should mention that I do not have spray equipment, but will be using spray bombs... primer (1 coat) then satin black lacquer (2 coats) then a final coat of clear satin lacquer.
Any insight into the above will be greatly appreciated. I should mention that I will be doing a light sand after soaking with lacquer thinner and scrubbing....
regards
Mike
Re: Re-finishing Question
Whew!
>First, I have got to tell you that you might want to have a professional refinisher take this commission off your hands, or find one and add your commission to his fee.
To blow black lacquer over an existing lacquer finish is not a complicated procedure. No preparation, except a cursory wipedown with lacquer thinner, should be needed.
If you really want to do this job yourself, with spray cans, go for it, but I really think you would get a better job from someone with the right facilities.
Two ¢ for you ...
Ellis Walentine, Host
Re: Whew!
Dick Coers
>I agree with Ellis. Spray bombs are no way to spray a table. There is no tougher piece of furniture to finish than a table. When the surface is parallel to the floor, you can always get some light reflection across the surface from somewhere, windows, lights, etc... That shows EVERY imperfection. And you will really be getting those from spray bombs. They don't atomize the lacquer very well. Then it will start to flash off before you get the whole table sprayed. That will increase the orange peel look alot. It will be really easy to get runs on the vertical surfaces too. If you have to spray it, go to Harbor Freight and you can get a Chinese spray gun for less than $20. Rent a compressor if you have to. I think that wipping with lacquer thinner is risky as well. It will bite into the old lacquer really quickly and if the rag sticks, you will have to sand it smooth. My concern would be contamination from "Pledge" type polish used on the table. Any of that and you could get fisheye in the finish. Wipping with lacquer will not take off any silicon that was in the polish. You really don't have to prime it either. Each coat of lacquer melts into the previous coat.
One last thought, I know there are alot of thoughts already. Straight lacquer has a really poor resistance to water and heat. If it was done comercially it might be precatalyzed lacquer, or even post catalyzed lacquer. There might be a compatability problem then.
Re: Whew!
Mike Turner
>I understand what you are saying... I am not planning to spray the table top as that is going to be finished with a stain and varathene... only the legs and skirt of the table will be sprayed... I will be removing the table top prior to spraying finishing legs and skirt.
I may have the chairs and table legs and skirt spray professionally. My main question was how much of the original lacquer finish should be remove prior ro re-spraying with lacquer..
I think you have answered my question... (I don't need to take it down to the wood) before re=applying black lacquer..
thanks much....
mike
Re: Whew!
Sgian Dubh
>Adding further coats of lacquer over existing lacquer can cause real problems, depending on the type of existing lacquer. Of the nitrocellulose family, there's really only nitrocellulose lacquer itself that will build successfully coat upon coat.
Most pre-catalysed lacquers, melamine lacquers, acid catalysed lacquers, etc, have dry coat finish thickness limits that if exceeded cause cracking and, in severe cases, crazing or chinese writing. The dry film thickness limit to prevent cracking/crazing/chinese writing for most pre-cats for example is ~4 mils (4/1000"). This is the result of applying two wet films of 4 to 5 mils each, and three coats at this wet film thickness is about as far as the polish should be pushed.
So, adding more lacquer over the existing lacquer could cause serious customer dissatisfaction in the short to medium term, ie, a few weeks to a few months, which could entail you redoing the job from scratch at no charge.
In your case then, and without the benefit of actually testing to find out what's already on this suite of furniture, I suspect you might really need to strip to bare wood and start again. If you're not fully au fait with wood finishing techniques in general and spray finishing techniques in particular-- you say you don't even own a spray gun, then I'd give this job a big wide body swerve. Slainte.
