keeping flat screens kool
mike mcnerney
>I just installed my 3rd. flat screen. A sharpe 42" lcd. I don't think it is plasma?
It seems to be shutting off because of excessive heat. I had a chanel of air running behind it from floor to ceiling & a a few holes behind the screen where it mounts & a 1/2" air space around the front perimeter, of the screen itself,
So I have now cut a 2 sq. ft. air hole to the left of the mounting bracket which has a big opening behind it which connects my floor to ceiling 'duct'.
What have people done? Any one use fans, what kind?
thanks
mike mcnerney in Ottawa.
Re: keeping flat screens kool
Jim in Burlington Ont.
Sounds defective to me
>I've never had any of those problems. We run 8 screens at work 24/7 and most makes seem to last quite a while.
Sender back
Dustmaker Mike
>We have 4 mounted in a wall at work with very little cooling air around them and they run 24/7. We have not had one fail. Now the DVD players on the other hand fail about once every 6 or so months. We put a Laptop running one to see how long it lasted about 7 months now with out any hiccups yet. Mine at home a Philips 42 inch Plasma sits in a corner next to a large window and does not overheat so I say sender back to geter fixed.
Re: Sounds defective to me
mike mcnerney
>maybe I wasn't clear it is inside a cabinet & I tried to descibe the clearances in my original post?
mike mcnerney
Re: keeping flat screens kool *LINK*
Paul Dwight
>LCD sets are not known for producing a lot of heat. The lamp generates some heat, but it seldom causes problems. In contrast, plasmas generate quite a bit of heat and require well-designed air flow if they're flush mounted in a cabinet. Sharpe is well known for their LCD sets but as far as I know, they don't market plasmas -- which means your set should be an LCD panel, as you thought.
I guess the first thing I would try would be turning down the lamp to see if that helps. The lamp (or backlight) normally can be set to one of three settings. Manufacturers always ship with the lamp set to the brightest, "torch" setting. The brightest setting looks great in a bright showroom but it isn't always needed in a home and it definitely generates the most heat. Turn the lamp down to the middle or low setting and see if that eliminates the overheating problem.
If turning down the lamp doesn't fix it, you'll need to re-examine the air flow in the cabinet. Air needs to enter the cabinet somewhere below the TV and exit somewhere above the TV. The flow of air needs to move over the openings in the TV that vent its internal heat. The air inlet and the air outlet should be about the same size -- having a giant inlet won't help if the outlet is small.
If you don't find problems with the air flow, then you may just need to move more air -- in which case one or more fans might be needed. The link below is a source I have used in the past. They offer good products, though they aren't the least expensive supplier around.
Hope something here helps. -- Paul
Cabinet venting fans at coolcomponents.com
