Sawmill - should I buy
Jeffrey D. Rose
>I have the opportunity to buy an Independence Machine Sawmill. Over the past few months I have gotten the price down to $1,200, it includes a 48" carbide tipped blade with sharpener, a 4 cylinder GM diesel for the power plant, and everything else to have an operating mill. I would have to move it about 30 miles. The picture shows the mill from the carriage end. It has always been sheltered and it runs.
What thoughts are out there to but it or not? I haven't convinced myself yet, but at this price it is really tempting.
TIA
Jeff in Iowa.
Re: Sawmill - should I buy
>If I read your price correctly then that is less than the cost of a Unisaw. Sounds like a remarkable deal. The blade alone is worth a lot.
I assume you have a building to house the beast? Would this be for milling wood for your own use or developing a business? Either way, if you have the room and the ambition then I'd say it sounds like a great venture!
Tom
Ray Binnicker
>If I were 25 years younger I would jump all over it !!!!! Uhh, better make that 35 years. I really do envy you, or anyone, with that kind of opportunity. Not just for the potential income, but the pure enjoyment of it.
The best of luck.
Ray Binnicker
Pete in Holland, MI
>Is it a carbide tooth blade, or an inserted-tooth blade? Inserted would be better and cheaper to repair after a nail is found.
be careful
Tom Sontag - St. Louis
>Of course this could be awesome. Naturally it would take time away from other hobbies. I know a guy locally that bought into a similar arrangement and spent way too much time adjusting and repairing what he bought.
Make sure you see it in operation. Parts wear out and can make the machine just frustrating; my guy had worn rails (which required welding on new metal, grinding it flat etc.) and he could not get straight boards. Don't buy a worn out relic to use! At that price though, even some small repairs would get you in cheaply. Of course, next you'll want a barn for the wood and a front end loader and a metal detector and ....
Re: be careful
Kneale Brownson in sunny N. MI
>Be aware too that that type of mill needs to have very accurately constructed foundations to operate accurately. My BIL spent more time figuring out, forming and pouring the foundation piers for his mill than he did building the shelter for it.
JKJ in East TN
>Jeff,
I did quite a bit of checking before I bought my sawmill. You might try asking around on some of the sawmill forums such as:
http://www.woodweb.com/cgi-bin/forums/sawdry.pl
http://www.forestryforum.com/board/
Besides the mentioned huge investment in infrastructure to set up and support a large sawmill, something to keep in mind is the big circular mills can be extremely dangerous. The kickback is similar to what you might get with a table saw except it can throw a 2x12 right through you and the wall behind you. Nearly everyone setting up a sawmill today, whether for casual or commercial use, seems to be going with a bandsaw mill. (The exception is the swing mills for log size and portability reasons.) We have a huge local hardwood mill that uses the biggest vertical bandsaw I've ever seen. Small mills are available for personal use.
Other considerations: a circular blade may take a 1/4" kerf while a band mill wastes far less wood; hit some metal and the downtime with a bandsaw is only a few minutes; bandsaw mills can be set up on nearly any flat spot (right on the ground) and can be portable;...
I bought a new Woodmizer LT-15 bandmill a few years ago - it was delivered in a few days by Fedex and I had it set up and running the same day. This is a manual mill and will cut up to 28" logs any length you want (just add "inexpensive" track sections. I've made very good use of it so far (but not in this heat - 101F yesterday!)
Jeffrey D. Rose
>Yes you read the price correctly. I priced the sharpener and it is about $500 alone.
Jeffrey D. Rose
>It would mostly be for hobby, if a nieghbor needs something cut I could help them out.
Jeff in Iowa.
Jeffrey D. Rose
>Carbide Insert. I priced one of those and they are $1,400.
Re: be careful
Jeffrey D. Rose
>These are some of the concerns I have had. The mill is in good shape, and I did see it run, and got to pull the levers and all that fun stuff. (guy factor points +2) I may have to store it for a couple months before I can get the support structure built for it. Ofcourse the other concern is future needs, I do have a cheaper metal detector, but I have no loader, can use neighbors for now and no shelter as of now. THings to consider.
Jeffrey D. Rose
>Thanks for the links. That is a nice mill you have. Do you store it outdoors, or under cover?
JKJ in East TN
It sits outside, with a Woodmizer cover over the motor and a loose tarp over the saw. Seems to be surviving.
Jeffrey D. Rose
>How do you dry your lumber once it is cut? What was the largest hurdle you had cutting your own lumber?
Thanks,
Jeff in Iowa.
JKJ in East TN
I air dry all I cut, stickered at first in the sawyard then stacked in the barn loft. I bought the sawmill primarily to cut structrual lumber for sheds and barn so air dry is perfect. However, I have made some shelves and other interior stuff from easy-drying y.poplar, letting it acclimate in the garage. Someday when I start using it for furniture I may build a solar kiln. At the moment, I'm accumulating y.poplar, pine, oak, cherry, walnut, and a little maple, persimmon, and black locust.
The biggest hassle in cutting lumber is dealing with the logs. Since word got out I have a sawmill, there is no shortage of free logs to add to trees from my own property (from stormfall and trees that needed to be removed). I would have piles of hundreds if I took them all, but each log takes an effort. I have a 1-ton flatbed truck I usually haul with and can sometimes position it to where I can roll a few logs up a ramp using a winch, but it is generally easier and often necessary to trailer the tractor to the site and use the front end loader to move and put the logs on the truck. I have 3/8" grab hooks welded on the bucket and use dual skidding tongs to lift and position logs.
For a small mill like mine without hydraulics, loading the logs and turning heavy cants is also a job. I use the tractor again to load the logs on the sawmill, then turn the cants manually with a 5' cant hook. But try to turn a 12' 20"x20" wet cant by hand by yourself - it's not only challenging but can be dangerous. Handling the green boards is another issue - I offload boards directly onto forks mounted on the tractor, then move to where they will be stacked. Even stacking boards is difficult without help - wet 2x stock is HEAVY!
However, it sure is worth it when it's time to use the wood. For example, when I needed to build a horse stall in the barn, it was nice to drive a forkload of "free" southern pine up to the stall door instead of making a trip to the bank and then to the lumberyard! It will still be a while before the mill pays for itself, but there's a certain satisfaction in petting a horse in a stall built with lumber from a downed tree from your own property. :)
Jeffrey D. Rose
>Wow, thanks for the informative responce.
Jeff in Iowa.
