planer storage
planer storage
planer storage
>My planer is in the way. I don't have that big a shop and I have my Dewalt planer on a table. The problem is that is sits higher than my table saw so when I'm cutting larger stuff I have to move it.
I thought about placing it lower than the saw but then when you really need it you'll hurt your back bending over. I did set up the jointer so it's fence is a hair lower than the table saw. That way it sits just to the left of the saw is not in the way and instantly accessible when jointing and sizing boards.
So here's the solution I'm thinking of. I want to build a rotating table top stand. I could flip the planer to the bottom side when I don't need it. The table top would act as an outfeed table for larger pieces or even a work surface. then when I need the planer I could rotate it into the working position.
I see two problems with this. One is the weight of the planer. It's not light. I would probably have to add springs or a counter balance to make it easier to move. The second problem is dust collection although that's easy enough to attach and detach when needed.
Anyone have a better idea.
Re: planer storage
Re: planer storage
>Good Afternoon John,
My guess is that your present arrangement of having the planer sit above the level of tour table saw is a bigger problem than managing its use on a rotating table. I think that is a fine idea. Whether or not you need springs or a counter balance is yet to be seen. I'd say Go For It. I don't believe the planer's weight is much to worry about. Three quarter ply, machine bolts and fender washers ought to be plenty strong, and you'll probably frame the table top anyway to accommodate the swivel with hardwood. And, in the event you do need a counter balance, you could always put another tool on the other side of the table. I've been toying with that alternative myself: DeWalt planer and Ryobi OSS on either side of a single swivel table top. Re dust collection: I just slip the 4" plastic flex hose over the planer's dust port. I don't need a clamp, just a friction fit.
George
George
Re: planer storage
Re: planer storage
>I think Chico posted a picture of a flip top stand he built. Might have been a year ago.
I have been thinking about it myself. My shops keeps getting smaller or maybe I keep adding stuff. The bed extension on my lathe took the spot my planer used to park. I am thinking of a flip top unit so that the top of the planer will be the same height as the band saw table. Right now its about an inch too high. Thinking of my slow speed grinder as the other Item to flip. Trying to figure out how to make it a tool caddy for the lathe also.
Wonder how I could make it low enough to park under the bed extention on the lathe and then rise or pop up to a height that would be convenient for planing and sharpening?
Re: planer storage
Re: planer storage
>I thought about putting another tool on the other side but then that doesn't solve the problem of cutting up a sheet of plywood. The tool would still be in the way.
Re: planer storage
Re: planer storage
>Barry I thought about some sort of foot operated scissor system to raise and lower the tool. Then it could be stored in the down position and with a quick step on a lever raise it up to a locked higher position. Mechanically a little more difficult but the flipping table will be reallly awkward at the 90 degree point with all the weight of the planer on one side. That's why I was thinking of a counter weight spring.
Re: planer storage
Re: planer storage
Alan Bierbaum, near Denver, CO
>John - I built a flip over stand for my planer several years ago. When down; the Formica covered table surface is even with the top of my table saw. When the planer is in use; everything runs through it and clears the table saw (and other tools). I used a piece of 1/2" all thread for a pivot. It is fairly easy to flip over for use and to store it (the planer is a bear to lift by itself though). No plans.
Re: planer storage
Re: planer storage
>Thanks Alan. That's exactly what I wanted to do. I don't think my planer is that much heavier than yours. I'm going to start building.
Re: planer storage
Re: planer storage
JKJ in East TN
>I don't know if it will work for you, but the cabinet shop down the hill from me keeps their large planer outside under a shed roof. I saw now rust on it. An advantage is it needs no dust collection system - they just blow the shavings into a big pile which is removed occasionally by a local farmer. They plane a lot of wood.
Re: planer storage
Re: planer storage
>John I'd love to do that. Do you think my neighbors would get angry over a 10 foot pile of shaving in their back yard. I could throw fertilizer on it and tell them I 'm donating my mulch pile to them.
