Veritas - Innovation in Tools
Rebuilding air nailer
Ernie Miller
>is it worth my time and energy to try and rebuild an oiless air nailer? it is an older Craftsman and has provide years of good service up untill a couple weeks ago I used it hard all day installing some paneling and the next day it was dead. I'm thinking my evaperator may have failed and allowed some watter to pass. is this a tough job? worth the effort os should I be off to buy another one. I don't use it often so I would have to think twice before buying again as I can do things the old way almost as easy.
Re: Rebuilding air nailer
Rick L
Re: Depends...
Rick L
>on how old. Water shouldn't do much to harm it. Lack of oil could cause soemthing to bind. O-rings wear and break. Some fixes are easy and then again some guns can be a pain to fix. Used to fix them professionally so I know. If you haven't worked on them it's hard to say if you can do it. We sold a lot of guns becasue we serviced them so if you buy a new gun find a place that sells and services them.
Re: Depends...
Ernie Miller
>It is probably 8 years old? actualy an 18 GA nailer for small stuff and an oiless type gun. Didn't know if it was worth the energy to play around looking for a problem or if I should jsut move on. I figured it was probably an O ring or somthing could have gotten bound? and a simple tinkering would either fix it of fix it so it can't be fixed.
Re: Depends...
>I just put one of my Senco guns in the shop and they fixed it for about $50. $12.50 parts and $37.50 labor.
I think you can buy a rebuild kit for many guns for about $10. O rings and such.
I figured the kit would not have some part I needed and I would end up making several trips to the shop and spending hours and gas on it. I think I was right. It needed a "negator" spring (?). Who knew?
Also, you can buy similar guns at Harbor Freight for as little as $20, so why bother to fix one. I paid $200 or more for mine years ago, but I did not know abut HF then.
