Melamine ?
Melamine ?
Melamine ?
Jerry Klug
>I am starting to build the scrap wood shorts storage unit in the latest Shop Notes. The project recommends MDF for the carcase boxes and I was wondering how Malamine would work. I don't have any experience with Melamine and would like some comments on the substitution.
Re: Melamine ?
Re: Melamine ?
SteveM
>I've used it for shelves, counter, assembly bench, etc. but for construction I'm think'n its a mite brittle. Chips and chunks if a screw or nail isn't just right. Might just be me though.
Re: Melamine ?
Re: Melamine ?
Dick Coers
>Melamine will work well. It takes a good blade to limit the chip out on the table saw. For really nice cuts, lower the blade to cut 1/8 deep or less, then bring it back around and raise the blade to cut through. Because it's so heavy, maybe cut wide to get it close to size in one pass, then come back and double cut for clean sizing. The chips can be tough on your hands, they are very sharp. I like to use confirmant screws in the particle board. I think Roo-glue is the only stuff that really sticks to the melamine if you have to butt glue to the melamine face. It looks good and is really slick when sliding material on it.
Re: Melamine ?
Re: Melamine ?
Rob Hix - King George, VA
>Jerry,
I love melamine. All of my shop cabinets have it in them somewhere. In my opinion is is a little less dusty than MDF. At least the cloud does not seem as thick when I cut it versus cutting MDF. As far as glue, if you must use it, the only glue I know of that will glue to the melamine surface is Roo-Glue. If I feel like I need to glue, then I will cut rabbets/dadoes or whatever in order to the the melamine surface off. This allows gluing of the partcleboard surfaces together which does really good with normal glue. Plus, any squeeze-out will be on the melamine surface and can be removed easily.
First warning. The stuff is about 100 lbs. per sheet. Some of my buddies say the Gorilla Gripper (www.gorillagripper.com) works goof to handle the stuff.
Second warning. The edges are SHARP. I cannot tell you of the cuts I have gotten with this stuff. Nothing hospital worthy, but be careful. The line between the melamine and the particleboard will get you.
As far as covering edges, I get the iron on edge-banding and go to it.
Have fun and enjoy working with it. I think it will be a fine substitue for your project.
Rob Hix
