Have a question? Ask Woody!
The endless project is done!
Steve Kreitler
>Doesn't look that hard, does it? And, really, it wasn't- once I got to the point that I could start cutting the wood.
The problem here is the customer's choice of wood. I tried to talk him into letting me use some old growth pine 1x12's that I've been looking to use, but he insisted on using local mesquite.
The mesquite is where the troubles began. The man who mills and sells it here locally (Abilene, Texas) doesn't follow any of the proper drying procedures- he literally just saws it and piles it on the bare ground out in the weather- not even stickered!
When I got the stuff it was checked and sprung along the grain- I had to fill all of these gaping voids with epoxy (it shows as the larger black lines in the pics). Luckily, I had just stocked up on bulk epoxy for my efforts in building post office box banks from Corian- I used about a third of my half-gallon supply on this, and it seemed to take forever.
None of the boards were wide enough for the sides, so I eventually resawed one, and bookmatched, glueing the pieces to some 1/2" birch ply in hopes of stalizing and strengthening it. The bottom is 3/4" ply edged with mesquite, and the top is a solid mesquite board, with a 2" wide strip of 1/2" birch dadoed into it to support the handle.
Two coats of danish oil, followed by two coats of paste wax, and the guts installed. The customer was happy, even though I cautioned him that I can't guarantee the job with this wood.
Re: The endless project is done!
Well, I certainly hope
Joanne Adler in Pt. Pleasant, PA
>the customer's bass or guitar playing is as beautiful as the amp! That is gorgeous! Nice dovetails and bookmatching.
Phil Thien
>That is really stunning.
Very sweet
David Barnett - SW Florida
>Just looks 'right', like it was supposed to be that way. Mellow finish, too.
Ernie Miller
>Should there not be a WAV file included so we can give it a listen? looks good!
Gorgeous wood...
Jim Dillon
>... and wonderful craftmanship, especially with all the problems you had to deal with. Well worth the effort though. Thanks for posting.
Jim
>Steve, you did a masterful job on that item. I appreciate all you had to deal with--but is looks great.
George
Steve Kreitler
>Thanks for all the nice comments, folks!
It just occurred to me that this same time last year, I might not have been able to pull this project off. The difference is in the tools that I have aquired in the last year-
In preparing the wood, I made extensive use of my new (old) jackplane, aquired at a garage sale just a couple of months ago. I also used a Record #4 smoother, picked up at a living estate sale several months ago.
Building the case was made easy by the fact that I have invested in a Wixey digital angle guage, and the bottom of the line Incra miter guage. I highly reccomend both of these products- they make cutting precise miters quick and easy for those of us with only a tablesaw.
Clamping up the mitered sides was easy using my new Merle clamp (aquired at the above mentioned estate sale), and a band clamp found still in the package in a pile of junk from an auction (two bucks- and I got a nice big steel shelf out of the deal, too!).
The last new aquisition that helped in this project was the jig I used to make the dovetail splines- it's called a Kehoe jig. I purchased it from www.dovetailsplines.com after seeing someone mention it on here. This item works as advertised, and makes it very easy to use dovetails splines, as you don't have to fuss around getting a fit- the groove and spline have an identical taper, and you just tap them in until they fit, then trim. Lots of fun, and a great way to use up scrap wood. Nope, they didn't pay me to write that- I just like the product.
Oh, and the ROS I used for sanding it was five bucks at a garage sale!
