Re: A/V Cabinet: How would you vent this? *LINK*
Paul Dwight
>You need to provide a route for air to flow through the entire cabinet and over the components. Because hot air rises, the usual design has air entering the cabinet at the bottom and exiting the cabinet as high as possible. If your design has the air both entering and exiting the cabinet at the bottom, you'll get very nice air flow on the bottom shelf and none of the components above will see any relief.
If the cabinet sets up off the floor on legs, the low, inlet vent can easily be located on the bottom of the cabinet. If the cabinet has no legs -- like yours -- the inlet vent can be hidden in the toe kick.
Normally the high, exit vent is mounted on the rear of the cabinet. If that's not possible, you can sometimes provide adequate air flow by leaving a gap between the face frame and the cabinet top -- concealing the gap by letting the top overhang the face frame an inch or two.
With your existing cabinet, you can work out a means of getting air into the cabinet at the bottom. The real problem is how you get the hot air out of the cabinet at the top. I assume the cabinet is mounted hard against the rear wall. I would first look at what's on the other side of that wall. Can you put a vent through the wall? This might work if, for example, there's a good-sized closet on the other side of the wall.
If venting through the wall is not practical, I would probably open a vent between the electronics cabinet and the drawer cabinet next to it, and then put another vent in the opposite side of the drawer cabinet so that the hot air dumps into the open area at the center of the desk (where your legs would be if you were sitting at the desk). Put both exit vents as high and as far back as possible. Put a fan in the bottom of the cabinet to push fresh air into the cabinet and another fan in the last exit vent to pull hot air out of the cabinets. (Be sure you orient the fans correctly to get the push-pull effect.) As someone else mentioned, the fans can be plugged into the switched outlet on your receiver so they only come on when the receiver is powered up.
If you have solid shelves in the electronics cabinet you'll probably need to cut some holes to allow good air flow through and around the components.
If you look around you can find fans that mount in round holes, which makes it easy to use a hole saw in a drill to retrofit the fans in an existing cabinet. The link below shows one such fan I have used in the past. If you look around on the site a bit they also have some pretty good general information about venting electronics cabinets.
Hope this helps! -- Paul
Round vent fans at coolcomponents.com
