Bush Oil
Bush Oil
Bush Oil
Patrick Schupbach
>Does anyone have experience with Bush Oil from Curious Woods? It sounds like a good product. Any info would be great! Thanks
Re: Bush Oil
Kinda pricey
Ray Thompson - Middletown,IN
>But gives a nice soft feel and look. We have been experimenting on turnings but no reason not to use it on flat work. If you use it on flat work give us a report.
Ray
Re: Bush Oil
Re: Bush Oil
John D. Luke
>So that's what he used on us.
Re: Bush Oil
Re: Bush Oil
Howard Acheson
>It appears to be nothing more than an oil/varnish mixture very similar to most of the "Danish Oils" and "Tung Oil Finishes". It's nothing magic or unique. All these products can be closely simulated yourself by mixing equal parts of boiled linseed oil, your favorite varnish and mineral spirits.
Re: Bush Oil
Re: Bush Oil
Don O.
>Howard is basically correct in his assesment. I know Bill Bush and he tels me it has more varnish solids than most "Danish oils". I have used it for several years with great success, mostly on turnings but also on some flat projects. It's easy to apply-wipe on, wipe off. It's not meant as a final topcoat finish really. It should be allowed to completely cure before topcoating just like other oils. I have used it as a final finish on turnings and buffed it out to a very nice soft sheen. It does an excellent job of "popping" the grain and adds a soft amber color to the wood (like most oils).
BTW-Curious Woods is part of Curtis Lumber in Ballston Spa, NY where our turning club has its meetings. They are very generous and supportive of the local woodworking community. The staff are usually very nice and knowledgeable about there products.
FYI-Bill Bush also buils very high-end custom furniture and teaches design. Even his daughter has won awards at our annual Fine Woodworking Showcase in Saratoga Springs, NY which we put on each spring.
