200+ woodworking book reviews
finish on maple dining room table
Doreen Scott
>hello!
We have a 35+ year old Ethan Allen maple dining room table. I used a spray cleaner/wax (can't remember what brand - I pitched it) on top of table. The top is now dull. Don't know how to return finish to its original shine. Can you help?
Doreen Scott
Brentwood, TN
Re: finish on maple dining room table
Questions
>Whew. There is a whole decision tree for your question. I would first ask what happens when you wipe the table down with naphtha or mineral spirits (to get rid of the silicone wax in your aerosol product)? If it removes all the wax and spray, and leaves the color intact, you're in luck. You should be able to give it a coat of wipe on varnish and you'll be back in business.
I'm a Waterlox Original fan, but I just used a Circa 1850 product called Antique Paste Varnish that builds a really nice glossy coat in one application. That might be the kind of look and regime you're looking for.
Ellis Walentine, Host
Bill Tindall, E.TN
>If I read your post accurately the finish is still there, it is just dull? 4/0 steel wool and paste wax will take the finish back to a low luster. If that is not bright enough then rotten stone and mineral oil on a felt pad will take it to a bright almost gloss luster.
The finish is most likely lacquer. Another alternative is to take it to a refinisher and have them spray it with a top coat of lacquer, which should be cheap to do.
Re: Questions
Doreen Scott
>Thank you, Gentlemen... Am going to try Ellis' suggestion next week. If that doesn't work, will move on to Bill's idea. Will let you know if any of it works!
Doreen
