Where Hardwood Comes From 12- prices/buying
Bill Tindall, E.TN
>Where Hardwood Lumber Comes From 12- prices and buying
For those following this series note that I have skipped section 11. It will be on drying lumber and I�m not ready for it yet. Twelve, this one, will be the last article.
For this example I will use poplar. Its price tends to be more stable so my numbers will be more consistent. The prices are current for July 14, 2007. Prices for hardwood lumber are published weekly in trade publications such as the Hardwood Market Report.
Let us begin with a prime poplar log 12� long and 16� diameter. This log will scale 108 bd ft by the Doyle scale (see part 10 for a discussion of log scaling). The log will bring $35 delivered to the log yard (Part 3 and 3A) here in eastern Tennessee. Of the $35 the logger will get about $17.50 and the land owner $17.50 (see Part 10 on selling timber).
This log will yield abut 136 bd ft of lumber if sawed on a typical circle saw with �� kerf (see Parts 4 to 7) or more if the log is sawed more or less with a band saw which has a more narrow kerf. This log will typically yield lumber in all the grades #2 Common up to FAS (see Part 8). Current prices for �green� (right off the saw) 4/4 poplar are $790, 390, 295. Prices are always quoted per 1000 bdft. These prices are determined by demands in the various markets for these grades. Amateur woodworkers don�t buy enough lumber to have any significant impact on demand and price.
Let us assume this log yielded after grading (see Part 8) half FAS lumber, and one quarter each #1 and #2 Common. The mill would receive $54 for the FAS lumber, $13 for the #1 Common and $10 for the #2 Common, for a total of $77. In poplar the FAS grade will be largely clear lumber, #1 common boards will have one or two knots and #2 will look like knotty pine.
Next the lumber is dried. Prices for �KD�(kiln dried) 4/4 poplar are
$950, 560, 405 for the grades described above. Prices for KD 8/4 are $1015, 750 and 515 respectively. The 8/4 prices are higher because it takes longer to dry the thicker lumber, there is more downgrade from defects induced in drying thick lumber and another factor which is less obvious. Logs will yield less high grade lumber when sawed 8/4 than 4/4. The reason is that lumber is, with one exception, graded from the worst side of the piece. Adjacent saw cuts that yielded an FAS 4/4 board followed by a #2 common 4/4 board would yield one #2 common 8/4 board. The premium for 8/4 oak is especially high because it must be dried exceptionally slow to prevent cracking and even then there may be drying defects.
The quotes for KD lumber at the wholesale level will always state that the lumber is �measured before drying� and it may state that the grading is before drying. This is a code phrase to indicate that the KD tally (see Part 8 for tallying lumber) will have 7% added to it on the billing.
Sometimes it is had to rationalize the price difference between green and KD lumber. The obvious factors such as cost of drying are confounded with things like spot shortages for KD lumber and premiums for buying one grade.
Your local retail lumber store will likely pay more than $950 + 7% for the lumber in their rack. There will be shipping charges, which are not great, and the lumber may pass through one additional middle man on its way to the retail store. This middle man may do additional sorting of the lumber for the retail trade, especially in species like walnut and cherry where the differences in quality within the FAS1F&Btr grades (see part 8 ) is much greater than in the case for poplar. I will leave it to you all to see how much mark up there is at your local retailer.
We can see that there are many places along this �food chain� where the woodworker can buy lumber from trees in the forest to the retail store.
Other than the need for logging equipment, buying trees and logs has a special problem for the amateur woodworker. Beyond obvious defects like branches, an experienced timber person will see subtle irregularities in the bark to detect defects that lie within. The first walnut veneer log I ever bought to saw had a large rotten cavity hidden in its center and the log yielded mostly lower grade lumber. You will also need to learn to dry the wood without ruining it (no small task) and you will need to learn to efficiently use the lower grades of lumber from the logs in your projects. But if you have a trust worthy sawmill that will sell you logs this is by far the least expensive route to lumber. Additionally, one can pick logs that have figure or size that could be attractive. I recommend this route for the serious woodworker. Bribing the sawmill with cookies and woodworking trinkets is effective.
Buying graded lumber from a mill is more risk-free and it is only a somewhat more expensive route to lumber. However you won�t be able to pick logs that might yield figure or unusual sizes.
Neither of these routes is available to persons that don�t live where hardwood is produced. Lumber is marketed internationally, and shipping is cheap. Everywhere has a cabinet shop and they will have a source of lumber at near wholesale prices. Find out from these shops where they get their lumber. At least here in the southeast these suppliers will deliver a wholesale pack of lumber right to your door on the trucks they use for supplying cabinet shops. You may have to buy a minimum of 200 to 500 bdft and you will be buying by grade. Recall that within a grade, lumber may differ substantially in quality, especially so for walnut and cherry (see Part 8 ). The picture shows a shed at a typically wholesale operation. The forklift is for unloading and loading trucks. It can lift several thousand bdft of lumber at a time. When they get gravel on the tines and then lift a pack onto my truck the gravel embeds and it is not nice on planer blades. The colored ends on the lumber packs are purely cosmetic.
Another route to less expensive lumber is to buy the lower grades. The secret to working these lower grades is to learn to pick through a stash to find clear cuttings that efficiently make use of the clear wood between defects. Most of my furniture framing is cut from cheap #2 common poplar. If I have a good selection to choose from I have almost no waste. In walnut and cherry the #1 common grade is about one half the top grade price. This grade typically has less sap and an experienced woodworker with a good stash to choose from can work it with little waste. You might only need the higher grade to make a long table top.
