installing urethane tires on BS
Terry Alexander
>I gave my little sister a hand in putting on new tires for her BS. I couldn't figure any other way to get them on except to actually remove the wheels (time consuming) where I could get some good leverage on them on a flat surface.
Surely there is a "trick" to installing these.
I mean....there's a trick to everything (usually).
TIA
Terry Alexander
Re: installing urethane tires on BS
Lee Schierer - McKean, PA
>You need to heat them up and then you have to get them on qucikly before they cool. You need four hands to really do it on the saw. I've heard that spring type clamps help to hold the area where you started in place while you work your way around the wheel for the rest of the tire.
At least with urethane oyu won't be doing it again soon.
Lee
Robin Corell in Atascadero, CA
>I found it helpful to quickly dry them off after soaking in warm water. they were just too slipery when wet and wanted to slip off the wheels. when dry I had no trouble geting them on with the wheels on the saw. I Used carter brand, not an endorsement just wanted to let you know in case yours are a diferent brand so you know how my comments may or may not apply.
Robin Corell
wilbur
>If you've ever changed the tires on a bike, you already know how to change a bandsaw tire.
For changing a bike tire, a useful tool is a set of three tire irons. The same principle can be used to change a bandsaw tire. What I used were three spring clamps and a long screwdriver.
Soak the urethane bandsaw tire in hot water to get it more pliable. Dry it off. Clamp the tire to the bandsaw. Stretch the tire around the bandsaw as far as you can. Clamp the tire with the second spring clamp. Now go back to the first spring clamp and use the screwdriver to lever a section of the tire on in the opposite direction. Clamp it with the third spring clamp. Go back to the second and use the screwdriver to lever some more of the tire on, and move the second clamp over. Keep going back and forth. What will happen is that it will seem like it's impossible to get any more of the tire on, then suddenly it will get really easy.
