slotted wood base
Lisa
>How are the slots made in slotted basket bases?
slotted wood base
Lisa
Re: slotted wood base
Joanne Adler in Pt. Pleasant, PA
>Lisa,
I dont' know exactly, since I don't make them, but I did a search and came up with this site where you can buy them. Looks as if you'd need a lathe or a horizontal router to make that groove.
Here's the link in case the one below doesn't work.
http://www.basketmakerscatalog.com/Merchant5/merchant.mvc?Screen=CTGY&Store_Code=TBMC&Category_Code=WBASESL
Good luck!
Dennis Yoder
>I made some for LOML by cutting the blanks out with the circle cutting jig on the bandsaw. I smoothed them with a citcle cutting jig on the disc sander and rounded the edges with a router. I cut the slots with a slot cutting bit on the router table. I closed up the opening in my table fence and used it as the guide to index the disc. Dennis Y
