Adjusting drive belt on Performax question?
>I have a 16/32 Performax I bought used. The original drive belt was beat up, had ragged edges, but was functional. At some point I tried to make it track better and screwed up to the point it tracked into the control box and tore itself up. I found the adjustment process to be a little confusing. (I have left/right orientation "issues").
I bought and installed a new belt and it has been running for months, but it is too loose and tracking over toward the control box. I have left it alone because it does not appear to be doing any damage, but lately it has started to slip and fails to drive the pieces through. Time to adjust it again. (Insert trepidation here)
Can someone talk me through this? From the outbound end if I tighten one side more than the other does the belt move toward the tight side or the looser side?
