wood finishes
James A. Minor
>I have some old boiled linseed oil. How long is it good for?
Also, I have some paste wax for furniture. It has Mononk on the can. Does anyone know anything about it?
Thanks,
Jim
wood finishes
James A. Minor
Thanks,
Jim
Re: wood finishes
Dale Lenz
>James:
I've used BLO that was 15 years old and had no known problems. Although, the can of BLO was nearly full, so not much air to react with substance. I'd suggest you pour some on scrap wood and see if it dries.
Paste wax
>I don't know that brand, but paste waxes are more similar than different, at least after they have been applied and buffed and the solvent evaporated. Depending on the percentages of waxes with different melting points in the mixture -- all paste waxes are mixtures of things -- it may dry at a different rate or require more elbow grease to buff out, but in the end, they all leave a thin coat of wax on the surface of your wood. None offer much protection from anything but grime, but most result in a sheen and tactual quality that enhance the look and feel of even a tired finish.
Play with it and see if you like what it does.
Regarding old boiled linseed oil, I would experiment with that also. Just sand a piece of hardwood, wipe on a coat of your oil, wait a while and wipe off the excess. If it is dry in a few days, it's fine. Otherwise, it might retard further finishing coats. Don't use rosewood or ipe for this exercise.
Ellis Walentine, Host
