Way off topic: Disabling Toyota Tacoma alarm
David G. Sparks
>I'm trying to disable the alarm on my 2001 Toyota Tacoma pickup. I keep accidentally setting it off and am tired of disturbing the neighbors. The truck has power door locks and power windows. I haven't been able to find the correct procedure for disabling the alarm anywhere on the web. Thanks in advance for any help.
Re: Way off topic: Disabling Toyota Tacoma alarm
Try locking manually...
John in New Mexico
>Instead of using the little remote control thingy. I'm only familiar with two vehicles with factory alarms, but thats the way both of them work - lock the door and then close it... no alarm.
John
A.J. Hamler
A.J. Hamler
>Had the same problem on my Saturn, but buried somewhere in the manual is how to turn the thing off. It involves pushing and holding the remote buttons in a certain sequence -- push this one while holding that one or some such thing like that -- and it cancels the alarm. It's possible your Tacoma has something similar.
A.J.
Doug Reynolds in Seattle
>In some cars (my 2001 Civic) you can do that by putting the key in the ignition and pulling it out quickly three times. For my Honda, this is called the Valet Mode. If you have a flashing red light on your dash, see if this makes it come on or off or, if the system beebs once. Honda has other alarm modes that allow you to sort of custom the system for your needs. You can keep the remote entry feature and panic alarm but, disable the other alarm mostly so you can load or unload the car of groceries during a rain storm without having to unlock the doors each trip not, that it ever rains in Seattle. See if you can find a seperate manual for the security system or, a seperate fuse for the alarm.
I wonder, however, what this will do to your insurance if they find out you disabled your alarm and your car was broken into or stolen. Seattle has the sixth highest auto theft rate in the nation. Toyotas and Hondas are the most common target.
jeff
>My father in law had to take his Toyota to have it disabled.
Some sort of programming that was dealer only.
The built-in temporary system just wasn't working right.
I found out how to do it. Thanks!
David Sparks
