DC set up
Sean Troy
>Does anyone have a link that describes dust colection setup, particularly pipe selection, grounding, gates ect...? Thanks, Sean
DC set up
Sean Troy
I can save you 33% of your effort…
Rod Peterson -- Ormond Beach
>> particularly pipe selection, grounding, gates etc...?
Forget about grounding. It's not an issue, despite the hype you may run across on the web. In our very own Articles Section is Rod Cole's excellent treatise debunking much of the myth of grounding as it relates to dust collection. It's required reading for anyone planning to do a dust collection installation.
Now, my 2¢ with regard to the other two. Pipe size has a lot to do with the HP of your dust collector. It's too complex a subject to answer in a few short sentences (and I'm not the one with the knowledge to try, anyway). Pipe type is essentially two choices (three, if you separate the metal into two types): metal (spiral wound or not), and PVC. Expense and ease of handling lean toward PVC, but metal has pluses as well. It's not an easy either/or decision.
Insofar as gates are concerned, many folks make their own. The two other choices are the metal ones and the plastic ones. I don't think the plastic ones come in any size but 4", so that may tilt the scale if your choice of pipe size happens to be 6". They also are prone to clogging if you don't modify them. The metal ones, on the other hand are about 3-4 times as expensive. Could be short money considering long term, however.
I can name at least a dozen people (and probably more) here on WoodCentral who know way more than I do on this subject (except for the clogging plastic gates—I lead the league in experience on that score), so I hope you get some other, more informed replies.
Rod
Re: DC set up
Jesse in New Mexico
>Hey Sean,
Bringing up dust control is almost like bringing up religion. You are sure to get a lot of strongly held opposing views
Here's a place to start, Bill Pentz's webpage.
http://billpentz.com//woodworking/cyclone/index.cfm
Bill is highly knowledgeable and has strongly held opinions. Doesn't hurt to get a second or third opinion before spending $$.
FWIW, I've got an Oneida cyclone system with metal ducts and some plastic tubing at the ends. I bought the ductwork and the gates mostly from Oneida. They offer free design service when you buy from them, but it doesn't hurt to get a second opinion on that, either.
I'm happy with my system, except for the bandsaw and the miter saw - which are very hard to collect dust from on any system. One of these days I hope to get some DC on the top of my tablesaw, too.
Let us know if you have any specific questions. I know the folks here helped me enormously when I was trying to figure it all out.
