How are teh sides made?
Lee Schierer - McKean, PA
>LOML wants me to make a box like the one in the photo. I don't know how the sides are made. The box is 4-1/2 High x 12-1/2 long and 8'1/2 deep. Any one have any idea (and instructions) of how to make the curved sides on a box like this. 12" seems a bit long to try to cut the curve standing on end on a band saw.
Thanks,
Lee
Re: How are teh sides made?
Say hello to Williams & Hussey…
Rod Peterson -- Ormond Beach
>That would be one way, but even though I subscribe to the new job, new tool philosophy, that's a little steep for a one-off like this.
Suggestion #2 is to do the cove profile on the table saw, and then use a molding head or router table to do the rounded over profile. I hope it's obvious that I'm talking about stock preparation here, with the usual miter, glue, and clamp for construction of the box from same.
Short of the Williams & Hussey, you're almost assuredly going to be doing the molding stock as a composite of techniques, I would think.
Good luck.
Rod
>Good Morning Lee,
I think Rod has the technique/method. My #3 son made one for his then fiance' from modified stock molding purchased at a lumber yard. I can't remember the specie of stock he used, but it came out beautifully. I'd invest in a nice architectural router bit(s) and proceed as Rod says with the wood specie of choice.
Geoprge
Re: How are teh sides made? *LINK*
>Eagle and others sell router bits to make these sides.
Also look at http://www.eagleamerica.com/product.asp?pn=199-1405 for the sets. I've been thinking about buying a set eventually.
Box side bits
Ray Thompson - Middletown,IN
>I used a router with cove bit to rough out the profile and finished with a custom made scraper. I drew the profile on the end of the board and routed to the line as close as possible, usually with small cuts. Then I cut out the profile on a piece of sheet metal, when done I pitched the scraper since it didn't have an electrical cord.
Ray
Re: Looks exactly like the profile in an article
Al Crandall (N.E. of Indy)
>Looks exactly like the profile in an article in Wood magazine, March 1998 issue 104. The article is on making boxes from crown molding. There is a square box on page 73 which looks like it is the same profile as your rectangular box. Keep it simple! Al
H & R molding planes
Michael Stadulis, in Gloucester County, NJ
>With two or four Hollows and rounds and your table saw, you can do that very easily. I have replicated the older profiled crown moldings this way. I was a bit scared at first, but it goes fairly quickly. Know anyone with a decent set of H&R's ? Ping me if you need more detail.
Mike
Network
>There are a bunch of ways to make moldings, but the most cost effective will probably be to just buy X number of running feet of it from someone with a sticker or four-sided molder. Lumberyards don't ordinarily have hardwood moldings in stock, though the better ones can order it for you.
Instead, I suggest you network yourself to a local millwork shop and see what offcuts they have from past jobs. You don't want to have them set up to run five feet of molding, because the setup and run costs will drive that molding's cost to about $20 or more per foot.
You can surely make virtually any profile yourself, finishing up with a custom scraper like Ray suggested, but it's a fair amount of work for a couple running feet of molding. Your call.
Let us know what you do....
Addendum
>Actually Lee,
Ken has made a number of them from 2 1/2" cove molding as well as other dimensions. He worked for a custom millwork firm for several years and had ready access to offcuts/leftover special order moldings of cherry, mahogany etc. as well as the standard pine. What Ellis said below is right on.
George
Try one of these router bits. *LINK*
Craig Daymon
>If one of these don't match it, I suspect someone else makes one that does. I'm guessing those sides are only about 2-3" high. Freud or CMT might have a bigger selection in this type.
-Craig
P.S. Would anyone else prefer to put the title of a URL in before putting in the link? I always seem to be pasting twice to get it right. (Probably too late to change it.)
MLCS Moldign Plane Profile Cutters
this is much easier than it sounds
Bill Tindall, E.TN
>First let me preface by saying that I faced a similar problem with a short run of molding and fretted about it for months, avoiding what sounded like an onerous task of making it by hand. Well, it turned out to be amazingly easy to make it by hand, like less than an hour.
Select straight grained lumber. (I suspect coarse grained wood like oak won't work well, but walnut was easy.) Draw the profile on the end of the board. Using a rip blade, or router bit and table, or any combination of wood removing cutters waste out as much or the wood as you can, cutting up to the scribe line you made on the board end. (leave some extra wood on each side of the molding to support the piece while making the profile. You will be left with small ridges, that when removed, will yield the desired molding. These ridges are removed amazing easily with a sharp scraper. The molding may not be perfect along its length so make miter cuts adjacent to one another for each corner. You will be amazed how quickly the profile developes.
Re: this is much easier than it sounds
Jim Shaver - Oakville, Ontario
>I was thinking the same thing Bill,
I know that using the table saw method can create a cove at a high angle like the picture shows, but to create the whole profile will also require some work with a series of router bits...6/4 stock for sure at a minimum to start this I would think.
Take care,
Jim
My protocol has always been…
…to put the actual link in the “Optional Link URL” box (remembering to eliminate one of the “http://”s), and then put some kind of description in the “Optional Link Title” to make it attractive to potential clickers and readers. That's your goal—to get others to look at what you so proudly took the time and trouble to find.
I never use that method myself, preferring to code my own active link (easy to do), which I can place anywhere in my message rather than having it show up where the forum software wants to put it. Nothing inherently more or less desirable about either method.
If anyone needs to see what the actual link is, they can mouse over the link and read the URL on the bottom tool bar of their browser. If for some reason they might want to copy the link without actually going to it, they can right click on it and select “copy link location” to put it on their clip board then do with it what they will.
My preference is to always have a clickable (but not blind) link when finding resource information. I much prefer that to someone just typing (or pasting) the URL into their message as text. If one is going to that much effort, it's no more than a few keystrokes to provide a clickable link for the readers. That's what the web is all about anyway—links.
Rod
different approach
Bill Tindall, E.TN
>I was suggesting ripping out the waste as a series of stair steps either with a rip saw straight on or a round nosed router bit and then scraping smooth. It is surprisingly fast if you can sharpen a scraper.
Many ways to skin that cat.
Don henthorn
>I have made a number of boxes and plinths for cabinets with that form. I always found it pretty easy and fast to use the table saw to cut a cove with the blade tilted to get the main form right and then finish the other curves with hand planes. Use pencil lines to help you keep the form uniform over the length. Never had a problem. Take your time and enjoy the process.
Al's right....
Jim, outside Perth, Ont.
>It's exactly like the WOOD mag article. I've made a few of them in the past and they're just standard profile crown moulding.....here's one that I made as a trial run with a stock alder moulding (stain is really blotchy, but then that's why you do a trial run....I use it to store orphan screws!!). If you use a compound cut instead of a straight miter you can get some really neat looking results. The magazine article shows you all the cutting and clamping jigs that you need.
Its a piece of crown mould.
Pete In Millgrove
>You can buy it at any lumber yard
Secret code?
Kneale Brownson in sunny N. MI
>What's the secret to the coding, Rod? Is it as easy as {angle bracket img src equals "url.jpg" angle bracket} for images?
Roughly the same format, different tags.
>No big secret, and not difficult. To make a clickable link instead of an image tag (<img…>) you make an anchor tag (<a…>). I'm not sure why it's called anchor, but there you are. The other parameters are: href (presumably for http reference, but might not be—in any event it's how I think of it), an equal sign, then the URL itself, followed by a >. It's also good HTML practice to enclose the URL in quotes.
Unlike an image tag, however, you're not quite done. You then write the visible descriptor, which could simply be the URL again, although when doing so I would omit the http://www as it's generally unnecessary. Finally you close the anchor tag just like you would close a bold or italic tag with </a>. Here's how you would code the URL for my site (I've colored the different parts as they were discussed above):
<a href="http://www.woodbutcher.net">woodbutcher.net</a>
(note a space is needed between the tag type, “a” and the parameter, “href”. No other spaces are necessary, which is probably why the anchor tag looks sort of intimidating.)
which results in woodbutcher.net
Or, in a variation on the descriptor (but with the same clickable link):Rod's website
At first this seems like a lot of work, and it does take ten extra seconds of typing, although one usually cuts-and-pastes the URL obtained elsewhere. But after doing it a few times it will become automatic. And one can always simply use the “Optional Link URL”/“Optional Link Title” feature in the forum software to put a link in a post here at WoodCentral.
Rod
Re: Roughly the same format, different tags.
>Thanks, Rod. A few extra keystrokes, but about as easy as using a tinyurl, which I understand you dislike.
Re: Hey, Rod
>Some forum software doesn't permit direct HTML coding. Sometimes they have alternate formatting (using "[" and "]" instead of "<" and ">", for example). Other times they do their own direct linking based on the "http://..." format URL typed into text (that's what my email and usenet clients do, but that's user side functionality).
I didn't think about that when I wrote my piece. I guess I should have included a “WoodCentral only” caveat.
Rod
Re: Hey, Rod
>The forum I tried it on has an automatic links function that puts the link descriptor at the bottom of the page. It also has an automatic image function that puts the image at the top of the page. It allows me to use image insertion coding to put the image in the middle of the message or wherever I want. Wonder why it wouldn't accipt the links insertion coding.
If you just want the standard shape then a
Don henthorn
>molding will do. If you are doing something unique to reflect your own design and aesthetic ideas then a molding won't do. Neither approach is better than the other. Just depends upon your goal for the project.
