Compound Miter Saw Dust Collection
Brian McKearney
Brian McKearney
>Does anyone have an pictures that they'd be willing to post of a dust collection device/strategy that is effective for a Compound Miter Saw? I have a dust collection system in my shop and it works pretty well for most of my major tools, but I'm kind of stumped when it comes to the Compound Miter Saw.
If anyone has any pictures or suggestions, I'd be grateful.
Brian
Re: Compound Miter Saw Dust Collection
Ells in Boulder
>I've seem some pics on this site, I believe, but not sure where just now. Might try a couple searches.
Ells
Check the Articles Section.
Rod Peterson -- Ormond Beach
>I know I worked on one within the last year. It should be easily found there with the most rudimentary search (we load up a META argument pretty well with potential search strings, so “dust, cullection, or compound” all should yield useful results.
Rod
Jim Dillon
>Brian,
Don't feel bad about being stumped on dust collection for a CMS; it's is tough to do in my experience. I hung a large box off the rear end of my CMS saw to at least contain the dust and even have a vac hooked up to the CMS dust collection port but the latter is pretty worthless. Plus, the saw/box footprint becomes huge. I've seen pics of setups for regular miter saws, but the CMS is much more difficult to find a solution for and still retain the advantages of a CMS IMHO. Someone (Oneida?) made a dust collection port that actually goes UNDER the base of the saw to pull dust downward; but I guess that only works with saws that are open at the bottom. Hopefully, someone will have a better solution for you. Good luck.
Jim
While I dont have a pic of mine......
Scott in Eastern Iowa
>.....I can explain it a bit.
After seeing several dozen square or rounded dust collection areas behind the CMS on various forums, I discovered my strategy and setup quite by accident.
While using a piece of EPDM rubber to serve as a temporary backdrop for my CMS setup till I got my then rounded DC shroud built, I attached a piece of EPDM from a shelf bottom and then simply pinched the bottom back of the hanging rubber to make a point....as in the point of a triangle.
If you watch the way sawdust kicks back behind the CMS and then flies around, ...(usually bouncing forward to onto the cutting surface) ...the sharp angle of the triangular point directs the sawdust to a central area and then it falls pretty much straight down. Now you can either drop the spent sawdust into a box, a barrel or add a 4" dust port to get the sawdust.
While its not perfect, (you will have some left behind the saw), it seems to me I have alot less sawdust to mess with....and I dont have it hooked up to any dc either....just a tall skinny box to catch the majority of it.
If I moved it further back (> than 12" +/- as it is now) it would probably work even better. Hope that is clear as mud.....
gary s clarke
>here is my dc collection for my coumpound miter saw. the plans came from a magazine some where in my past. the box slides on electrical conduit and the dc is connected to an al register that I got at HD.
Re: dc pic 2
gary s clarke
>the box is moved and the miter saw is still at 45
>This is the cabinet with hood. Hood with integral ducting was formed out of 1/4" ply then fiberglassed on the outside. Storage holds lots. On 2 casters and a step caster so it moves easily, but "sits" down stable. Surface is formica with 2 30" wings that fold down. Draw is now through a 6" system; very little escapes. Lights and saw are powered by a locked switch inside the cabinet to keep little fingers, hands, etc. where they're supposed to be when the shop owner is not present.
Sliding Supports
Jim O in Davenport IA
>Here ix a pic of my SCMS set up
Gary
Dan Donaldson
>Those pictures are small for trying to see what they show. If you are having a problem getting them under the posting limit as bigger pictures, e-mail the original(big) ones to me and I will fix them for you.
Brian McKearney
Brian McKearney
>Thanks for all the replies - gave me some good ideas!
Brian
