REAL MILK PAINT
Cabriole Legs
Cabriole Legs
Cabriole Legs
Tomm
>I am having trouble finding 2 3/4 inch stock to make a set of cabriole legs. I am thinking about gluing some stock to make the legs but I question the final look. What do cabriole leg makers think about glued up stock for legs of this type? Thanks for your comments.
Re: Cabriole Legs
Re: Cabriole Legs
Jennifer@Indy.USA
>I'm not a cabriole leg maker, but I think a glue up might not be the best choice. There are many sources for stock large enough to make them from a solid blank. If you're going to invest the time and trouble to make them, I would suggest using the best stock you can for them. Just my two cents.
Jennifer
Re: Cabriole Legs
Re: Cabriole Legs
Keith Newton
>Why don't you just state where you are, and ask where you can find some 12/4 lumber of whatever you are looking for? There are lots of friendly people who like to help other woodworkers, but it is harder when nobody knows your location, and what you are after. There may be sources near you that you have not found.
Re: Cabriole Legs
Re: Cabriole Legs
Dan Donaldson
>You really should get the right stock. It is unlikely that you will be able to glue them up and not have the gluelines show. If you are going to put the work into them, it is not worth not getting the right look. As Keith mentioned, let us know where you are located and I am sure someone can help with a source. Also, check Woodfinder for a source close to you or mail order for what you want.
Re: Cabriole Legs
Re: Cabriole Legs
del schisler
>i have turned cabriole legs before A nice task to do I would have 5 legs Just in case you get the off set angle on 1 leg not set right What that will do is not have the end of the leg off set right You will know right away It is not right But it is too late for that one leg I have done that It is nice to have a back up leg good luck del
Re: Cabriole Legs
Re: Cabriole Legs
Paul Waddle
>I would prefer solid stock,but the shoulders(?) on all is a glue up. Depending on how you have to make the legs,I believe I would try a glue up. With my roto carve machine (a follower wheel profiler),its no problem to just crank one out. Good advice on making the fifth one,seems something unexpected comes along. Good luck,pw
Re: Cabriole Legs
Re: Cabriole Legs
>Good advice on telling us where you are and what you are actually looking for. Give us the city and state and the species and size you need. One of the good and bad things bout Wood Central is that we have people posting regularly from all over the US and around the world. The answer might be different if you in Australia or South America.
There are companies that make legs and sell them. I have never used any of them, but I think Norm did on one of his shows. Obviously others do too or they would not be in business. So, do you just want legs or do you want to MAKE legs?
Re: Cabriole Legs
Re: Cabriole Legs
>Good Morning Tomm,
I'd prefer to make mine from solid stock. If I had stock to glue-up, and this stuff had the same natural color and adjacent grain characteristics I would consider a glue-up. If my finish was going to employ a glaze or surface stain I would have no problem with a glue-up.
George
Re: Cabriole Legs
Re: Cabriole Legs
Bill Sampson
>I was in your situation a couple years ago and found exactly what I needed in 12/4 stock for cabriole legs at Groff and Groff Lumber about 15 miles south of Lancaster, Pa. GroffandGrofflumber.com
Bill Sampson, Richmond, Va
Re: Cabriole Legs
Re: Cabriole Legs
Dave in Haverford PA
>You can find this at www.adamswoodproducts.com. They call them turning squares.
