Full Drawer Slide Problems
Steve in Phoenix
>Actually, these are over exending slides. Over time, the slides will not completely extend. The part that gets stuck for the last inch or two is the middle section (of the tree parts of the slide). And the drawer can be pulled out to its full extended position with a little muscle. It happens to each slide at different times. And it has happened on another project with a different brand.
Anyone else experience this?
Thanks,
Steve
Re: Full Drawer Slide Problems
Jim Dillon
>Steve,
This strange behavior is puzzeling as modern-day slides work very well if installed correctly. First, check to make sure dirt, sawdust etc. didn't get trapped in the slide. There is usually a lubricant on the ball bearings that can really attract shop dirt. Second, are you allowing the right clearance between the moving drawer part of the slide and the fixed cabinet slide when you attach the slides? I've found that if the this is off, even a little, it really cuts down on the smooth extension of the drawer. Said another way, the two slide components shouldn't be jammed against one another, nor too far apart. I'm out of ideas, for now, so good luck.
Jim
Steve in Phoenix
>Jim,
I have 1/2" clearance between the drawer and the fixed members. and the width between the fixed members is constant over 20".
Thanks,
Steve
John Ballance
>I've experienced the same problem from time to time. It appears to me that the middle captured bearing mechanism seems to slowly reposition itself toward the rear of the slide, which then keeps the slide from pulling all the way out easily. Pulling a little harder relocates the middle bearing mechanism, and all works fine. My experience is that this "behavior" occurs when the drawer is repeatedly pulled only part way out, then pushed back in but not to the fully closed position.
Other than having to pull the drawer all the way out when it "sticks" part way out, I've experienced no long term problems with these modern bearing slides.
PS: I use full extension slides for my workshop drawers, and never had this problem, but on other drawers in the house, my wife has experienced the "sticking" problem. I attribute this to different approaches to opening and closing drawers.
Brian Hahn in SW Wisconsin
>I've had the same problem with full extension drawer slides. In my case, I found that it was caused by seasonal swelling that reduced the clearance for the slide. My solution was to allow slight more side clearance and to use the "tab" holes for mounting the slide to the frame. The tabs seem to flex just enough to adjust for seasonal swelling and shrinking of the wood and the drawers always move freely.
I fixed the existing sticky drawers by removing about 1/32" from the draw sides where the slide mounts (used a router).
>KV-8505 slides require 17/32" clearance. I build the drawers 1-1/16" smaller than the opening. I don't beleive we have ever had the problem you speak of with Knape & Vogt or Accuride slides.
Steve in Phoenix
>Thanks for the response. I'm not sure I understand your solution though. Could you let me know more detail?
Steve
Steve in Phoenix
>This is a drawer my wife uses many times during the day, and she says she never pulls it all the way out.
I guess we will have to discuss this...
Thanks!
Steve in Phoenix
>These are-scm 0608, and came with no instructions, so I went with 1/2" clearance.
I have not been able to find any instructions online.
Thanks,
Steve
Another thought... *LINK*
Jim Dillon
>... I had was that the mounting screw heads are somehow catching the moving slide. On some slides, these screws are indeed different than the normal wood screws and are undercut a bit to prevent catching. Here is a link to this type of screw. I've had luck with both Accuride and Blum full-extension slides and Lee Valley normal-extension slides, and I try to ensure that the screws supplied are fully seated and flush. Hope you find or have found a solution to your problem.
Jim
Undercut Head Screws
Re: Another thought...
Steve in Phoenix
>Jim,
Thanks alot. There is no scraping of the screw in this case. A previous response suggested that these file-drawer type slides need to be extended all the way. And my wife told me she never pulls the drawer out all the way, so she is going to from now on. When I got to thinking about it, how do I open a file cabinet drawer? Not only all the way, but until it slams to a stop. Maybe people are generally mare careful opening wooden drawers that metal? But these slides need to be opened all the way for proper funtioning?
Steve
>My drawer slides (Accuride) need a minimum clearance of 1/2" on each side, but they can handle a slightly larger spacing. The slide member that mounts to the frame has mounting holes that are located in tabs. Those tabs will flex enough to let the slide easily accommodate a larger spacing between the cabinet and the drawer. On new work, I allow an extra 1/32" on each side. The slide handles this without trouble and it allows for expansion and contraction of the cabinet and drawers due to humidity changes.
On the drawers that had a problem, I used a router to skim off about 1/32" from the drawer sides where the slides mount. Just to be safe I skimmed an area as wide as the full slide to eliminate any potential rubbing. If the drawers had detachable fronts, I would have used a jointer, but my drawers had fixed fronts.
I hope that clarifies my solution. If not, let me know.
