Securing aprons to tops question?
>Normally I secure aprons to tabletops using buttons or "8" fasteners. I've got a nice piece of whitish red oak that I'm making into a top (about 16-18" wide and 50" long).
What I am thinking of is securing the apron front to the top with dowels and glue and attaching the rest of the apron with buttons. The reason I'm doing this is because the front apron is 5/4 and will support a drawer. I figure this would give me a nice solid front.
Any good reasons why I shouldn't do this?
Re: Securing aprons to tops question?
>Good Afternoon JL,
I don't see any problem so long as the table top can expand and contract. The use of buttons or figure eights elsewhere should allow for wood movement in cross grain situations.
George
>Since your top's front edge will be fixed, all of the movement must be accomodated at the back of the piece, including a gap with the wall. In this configuration, I would tend to fix the top with stopped sliding dove tails or a full width slot in the side aprons and either mechanical Z-clips or T&G blocks. The sliding DT will leave the entire interior space free for use as drawer space, but they can be difficut to get fit properly. If you can add a sliding DT at the center point it would also help.
mm
MN deepwoods (Dave)
>Good Afternoon George, 8-)
What are these button you're talking about? Aren't the eights thin metal washer-like 8's with holes for a screw into the apron and the top?
Dave
>I typically use "buttons" rather than figure 8 fasteners. I.E. cut a dado in the apron side and use a small piece ("button") of rabbeted wood to lock into the apron and screw the "button" into the top.
Re: Thanks Colonel and Mark
