Forstner bit recommendation
Mike Cunningham (Cape May NJ)
>Hi,
When I post it's on the turning board but I have a question more suited to you guys.
I need a few new Forstner bits, I'm looking for opinions as to the best in so much as sharp and retaining that edge. I am not looking for a set but individual bits.
Thanks
Mike
Re: Forstner bit recommendation
Ray Binnicker
>Mike,
I've had pretty good luck with some of the Harbor Freight cheapo's. I've also had no so good luck with them, also. I have started replacing mine (when I find one that doesn't cut well anymore) with the Fisch brand. They seem to cut extremely clean and accurate holes. They aren't that very expensive; just a few dollars more than the "cheap" ones. If you're like me and you need to drill a hole with a forstner bit you want it to be perfect.
Ray Binnicker
Jim DeLaney, Austintown, Ohio
>I like the HSS ones from Lee Valley. Excellent bits, Good pricing, and Lee Valley's world-renowned customer service...
Jim D.
Howard Norman-Prescott, AZ
>I also have had good luck with the LV Forstner bits.
Howard
phil in NJ
>I like the saw-tooth LV bits even better. The one downside (if you're using them on the lathe) is that their total lengths are only 5-6", and with a 1/2" hex shank I haven't found an extension that works yet.
Dave's Not Here
>I've been more than pleased with the Freud forstner bits. They stay sharp a very long time and I can save freight charges and buy them locally.
J D Thomas
>Another vote for the Lee Valley HSS. They are excellent.
J D Thomas
ThomaStudios
>Yet another vote for the LV set. My sister gave me a set years ago. They are still working fine. I also have some of the larger size Rockler ones. They work well also.
Thanks Guys!
>I had been thinking about Freud and LV
Thanks Again!
Mike
Check here Phil
Dave Peebles Lyons, Ohio!
>Hi Phil,
Back a few years ago I was doing some large Frank Sudal type vessels that required some deep boring with Forstner bits. I found that Greenlee carried some entensions that fit the Lee Valley Forstner bits. I believe I found the extension at a local Lowes store.
I believe they are make for electrical work, but they worked great for what I was doing. A Google search turned up a lot of venders.
Dave
Re: Thanks Guys!
Mark Kauder, Phenix City, AL
>Mike,
If you are buying these for boring a hollow form, you would do better with spade bits. If not, no big deal. I sat through a hollowing demo with Don Derry, and he described how to fine tune spade bits.
If that is what it is for, let me know. It is too long to type out here, if that is not what you need it for.
Mark
Sounds like a good article
Dan Donaldson
>Might want to type it up and send it to articles@woodcentral.com. I am sure that there are many people that could benefit from something like that.
Yes
>Dave,
I bought my extensions at Lowe's.
Mike
Re: Thanks Guys!
>Hi Mark,
I do a lot of peppermills. I'm just about recovered from June 6 lumbar fusion (2 more weeks in the body brace and then 3 months of PT but I will be turning)and have a production run of 20 - 25 mills waiting. I'm not overly concerned about the shallow boring but the through boring I use a 1" and the several that I have are in need of help. I thought I'd buy two quality carbide bits.
Thanks,
Mike
