I will be using my router this weekend. Except for the router in my table, I haven't used a hand-held router for a looooong time. I need to rout a simple chamfer on a simple computer table top. Here's the stupid question: do I go clockwise or counter clockwise?!
This is one of those things I rarely do and for the life of me NEVER remember what direction to go in!
Maybe I'll draw a caveman type picture on the wall of the direction to rout...
>Not a stupid question at all--conunter-clockwise for outside edge. If you want a simple rule: "Point thumb of right hand at edge to route, extend index finger to point direction to run the router". Now if you need to climb cut, then the rule is reversed. Happy routing.
>...the answer is counterclockwise, from left to right on the edge facing you and then on around the other three edges. On really splintery woods, this can result in some pretty savage tearout, though not often with a chamfer bit unless you're taking a really big bite. In those cases, it is usually better to carefully climb-feed the bit, i.e., move it in a clockwise direction around the top.
Climb feeding is rarely done in one fell swoop, since the direction of feed makes the bit tend to move away from the edge instead of pulling it toward it. If you apply too much feed pressure, the torque of the cutting action can make the router want to literally run away from you, so you need to finesse the cut and let the router find the balance between depth of cut and controllability. Then go back and work your way down to the final pass by whatever degrees necessary. If you want to practice this technique, I'd suggest starting with a small bite, such as your little chamfer detail, since the potential for the router to run away from you is negligible. Just NEVER try it with large cutters, as the potential force can easily yank the router from the strongest hands. If you've never seen a live router dancing across the floor, count yourself fortunate. (Ask Carol Reed about this. :-)
Sorry for turning your question into a lecture on something else.
>Joe, counter clockwise is the general rule. If however and this is --A BIG... IF You are taking a large amount or are working with a very splintery wood- It is possible to take lighter passes clockwise till you have removed most of the material then finish off with a clockwise finish...
---WATCH IT!! though. You must really hold tight to the router in this case as the bit will tend to send the router down the workpiece...But based on your statement- Counter Clockwise is the way to go....
See ya later I have to rout some signs for a Geico commercial.
Sometimes I find it easier to think of where the chips will get spit out.
If they get spit out from behind (like the exhaust of a car) then you are climb-cutting and usually that's the wrong direction. The bit acts like a tire and it tends to run away from you. Appropriate in certain circumstances, but can be dangerous.
If the chips are going to be spit out to the side of the work then the bit it's going in the right direction.
The clockwise or counter-clockwise, inside or outside, always confuses me. I can remember righty-tighty and lefty-loosy, but clockwise-counter-inside-outside.... just confuses me.
>Dancing routers are what my students used to do to me when they would plug in the router without holding on to the darn thing and the switch was left on from a router table operation! Not good!
Confusion about direction of cut is solved by looking at the router bit. The 'flat' of the cutter is the leading edge and should be introduced to the wood fibers first. The router bit spins clockwise from your point of view when hand held. Therefore, the path you move the router is counterclockwise. In an table your view is at the opposite end of the bit, so things are reversed. Also you are moving the wood and not the router in the table. Just look at the bit and introduce the wood into the 'flat' of the router bit to determine the proper direction of either the router or the wood, depending on your operation.
All other things said about climb cutting (the opposite of the above) are true. There is a time and place, but is always done with a minimum amount of material being removed, or your router will be doing a dance that is downright scary!
BTW, I am glad to be back on-line. Been off since early May. Hope I was missed a little. :)
>I used to have a small sign tacked to the inside of a cabinet to remind me which way to feed when hand routing. I never could seem to remember correctly, probably terminal sometimers disease. But I read somewhere in a magazine, that when you hold the router, simply go in the direction of your right index finger pointed out from the handle. Easy. I no longer have that sign.
>I just recently put a switch on my router table and then realized that the router would always be in the "ON" position. So, I think I'll tape a label to the router base saying "TURN OFF BEFORE USING" because I know I'll forget when I swith to handheld activities. I'm a pretty poor dancer and I don't want the router showing me a thing or two.
>First of all, you should never have bought a stupid router. All of my tools are smart, as I need the advantage.
Secondly, I remember the "normal" feed direction as follows: when using a table, I feed right to left, so when using a router freehand, I move left to right on the front edge and just keep on going.
>The main reason I use a router is because I like the noise and my neighbors like it too. I always open the large tilt up door just for their benifit. Same thing with my planer. The dogs in the neighorhood like the noise also. They'll howl for half hour after I turn the machines off. They must want me to turn them back on. My very favorite noise maker is my chainsaw.
I like making noise too. Three cheers for the weekend chainsaw therapy club. (It's been to long since I played with my Poulan!)
Yes, as far as the router goes...I find that whether upside down, or inside out, 8-) my router seems to cut the safest when I push it, or the wood into it, such that the moving bit forces its blade into the wood. By doing that you are going 'against the flow'. If you push the opposite direction it tends to pull the board forward and can easily get out of control.
Also if you are routing a board with grain, route the end grain first then if there is any tear-out you can clean it up when you route the sides. Have fun.
I generally approach things like Ellis described, especially with woods that like to splinter such as hickory; a bad splinter tear (or even a small one) can be a disaster. Regardless of the bit shape, I will take a small cut first in the normal direction as others have described. If I get even the hint of splintering, I will switch to climb-cutting and take only small bites at a time. This, of coarse, works best with router bits that have bearing guides and are in a plunge router where you can control the depth of the cut easily. I don't think I have the skill, strength (or courage) to use climb-cutting in a handheld router with a nonbearing type bit. Good luck.
