Another contractor saw question
Tom Norton
>Will cast iron extention table,left side, from a Unisaw fit a contractor saw?
I am looking at doing some upgrades.
Tom Norton
Re: Another contractor saw question
Rod Peterson -- Ormond Beach
>“Fit” is not really the right word. There may not be matching bolt holes (easily drilled if necessary), but the length is almost assuredly the same (27" is kind of a standard depth for a contractor/cabinet saw). Shouldn't be a problem to adapt it.
Rod
James Watriss
>Wanted to throw in a bit mroe information if you haven't bought a saw yet...
The general international hybrid is somewhere between a unisaw and a contractor saw. It's just shy of $1000, but it does have a cabinet. The blade does have a shroud, and you can run a hose from the shroud down to the 4" port.
And, it has 2 12" cast iron wings, and a biesemeyer style fence. Since General used to make the actual biesemeyer fences, before Delta bought the name, they still make pretty much the exact same fence, but they call it a biesemeyer "style" fence instead.
It's not a full power cabinet saw to be sure, but neither is a contractor saw. But at least this one has the cabinet, blade shroud, and the extra cast iron.
Dunno if you've bought anything yet, but figured I'd put that one out there. I was pretty impressed with them, back when I worked at Woodcraft. I don't work there anymore, but I still think the saw's a pretty good deal.
