A55 Smoothing Plane
telephone wireing?
telephone wireing?
telephone wireing?
ernie miller
>I need to re wire a new phone jack the oldjask you screwed the green and the black wire to the little box and it worked. they don't have jacks at the hardware any more just CAT5 and you push the wires in to them which little blocks do I need to push the wires to get a dile tone? any one know? all of the instructions are written for some one who know about this stuff? I think it has room for 8 wires but my house only has four and I know only the black and green go to any thing the yellow and blue don't? about to be off a party line if I get this figured out.
Re: telephone wireing?
Dave Arbuckle, Plano, TX
>You need one pair, wired to the innermost pair on the jack. If your color code is standard, you'll use red and green. Most jacks I've dealt with have the color code on them, either printed in color on the jack or with little tiny letters.
Re: Punchdown Tool
JoeW in Detroit, MI
>If you are talking boaut the style of of jacks I'm thinking about, you may need a punchdown tool. It look like a small chisel with a notch in the balde. It is need to really get the wires into the jacks. I've tried without the tool and I was not able to get the line to work. If you need the tool, I've seen them for around $5 at the big orange box. Fancier tools can get pretty pricey.
Re: telephone wireing? *LINK*
wilbur
>Hi Ernie,
This webpage has everything you need to know about doing your own wiring.
To answer you r question: in the old phone wiring scheme, red and green go together, and black and yellow go together. These days, it's more likely white with blue marks and blue with white marks, which correspond to red an green, and then white with orange marks and orange with white marks, which correspond to black and yellow.
When I had to rewire the phone lines in my house, I found everything I needed at the local Borgs: wire, 66 and 110 blocks, punchdown tools.
Telephone wiring color codes
Also useful to point out…
Rod Peterson -- Ormond Beach
>Although “tip” and “ring” (has nothing to do with the “ring” noise your phone makes) are important considerations insofar as polarity is concerned, it's only in a nowadays relatively narrow set of circumstances. The old, dial type phones didn't care how they were connected. The TouchTone phones from Ma Bell before divestiture did care. If you wired them backwards the tones (DTMF—dual tone, multiple frequency) wouldn't work. Modern, aftermarket (post divestiture) phones usually are polarity insensitive.
Having said all that, whenever I do any phone wiring, I try to keep everything properly polarized (the fixtures you'll pick up are nicely color coded) because you never know when someday, someone will plug in a legacy Princess set and wonder why it won't dial out.
Rod
Re: polarity insensitive
Carol - Strawberry, AZ
>is most likely internally corrected polarity, Rod.
Carol,
former Telco technician (15 years)
I knew there was at least one of you around.
>Telco geeks, that is (and I mean that in the nicest possible way).
Yeah, polarity insensitive is the result outside the black box—internally corrected is the process inside the black box.
I'm just a reasonably informed, results oriented experimenter.
Thanks.
Rod
who wears his own geekiness as a badge of honor
Ernie Miller
>This is way not to much working for me? 8 spots to choose from the wire colors don't seem to make much sense why isn't there a sinple digram that says this punch goes the this pin? then I could wire it easily all this color coding when I don't think any of mine are right just is no fun. I think I will just take a long plug and hard wire it letting it stick out the front of the plate. Geek I am not!
