cove cut jig
cove cut jig
cove cut jig
Rick Snyder
>Just purchased the Rockler cove cutting table saw jig. Have not received it yet, but was wondering what table saw blade (tooth count) to use. Anyone else out there have one? Any likes or dislikes etc.?
Re: cove cut jig
Re: cove cut jig
Rob Stokes in North Vancouver
>Wow - I had no idea they made those. I've just clamped a stick or two onto the table saw and carved away.
Your feed rate is probably more important that the tooth count. And if possible, don't use an ATB blade, use with with flat tops instead and keep the cut size down.
I've coved (very successfully) with a WWII numerous times, I was just very slow on my last and final pass. I hardly needed any hand sanding before I went to finish.
Rob
Re: cove cut jig
Re: cove cut jig
Ken Krawford
>Rick,
One other thing I would add to Rob's suggestions is to raise the blade in very small increments. Like him, I've only used a shop made jig but it turned out great. It just took a lot of sanding.
Re: cove cut jig
Re: cove cut jig
Rick Snyder
>Thanks Rob and Ken for the insight on the cove cut jig.
Rick
