OT - Film Scanner
OT - Film Scanner
OT - Film Scanner
Hoa Dinh in Alameda
>Hi Folks,
I have a few thousand exposures of color 35mm negatives and APS in storage. I'd like to scan them to digital format for another form of archiving and for the ease of sorting & retrieving. These photos are family snapshots, so I doubt if they will ever get printed to more than 5"X7".
I found some reasonably-priced flatbed scanners with adapters to scan 35mm negatives and slides. But I have not found any with adapters for APS. A dedicated film scanner with APS adapter will put me back at least $700. My current budget is half that amount.
Can I use the flatbed scanner 35mm adapter for APS? I'm willing to pull the APS films out of the cartridge and cut them in strip.
Also, I need USB or Firewire interface, no SCSI.
Any recommendation?
Thanks,
-- Hoa
Re: OT - Film Scanner
NickB
>I haven't started the process yet, but my wife picked up a dedicated 35mm film/slide scanner from Costco several months ago (the idea is to archive all of the slides her parents have from days past). It claims a pretty high scanning resolution (3600x3600-higher than my flat bed goes) and uses a USB interface.
Hope this helps,
Nick
Steve Dart
>Hoa,
My Dad asked me to post. I am currently doing the same process for him. We have a Flat bed scanner with a 35 mil slide adapter. The real trick is having a scanner that can do high resoultion. personaly, I scan 8 at a time, at a very high resolution (720dpi). all eight are saved as a very large file...ussually ~250mb. then i copy the outputed file and crop and cut 8 smaller pictures from the original huge file. I then touch up lighting, colors and stuff like that... 8 slides take ~20 minutes.
arw01
>I've scanned thousands of slides and negatives over the years. You could pick up a Nikon Coolscan, use it for the project, and resell it on Ebay for a significant portion of the purchase price. That might be in your budget.
2700dpi works well for 11x14 size. use that as a quickie guide.
You could also check with a local mini-lab to see what they charge for scans. The APS rolls might not be too expensive to have them scan then to CD.
Alan
