Frequency Of Spark Plug Change-OT
>Good Afternoon Friends,
I spent part of the morning changing the plugs in my '93 Mazda B-2200 pick up. It has felt sluggish for about a year, and was working hard keeping up with traffic while hauling a load of cherry and poplar a couple weeks ago. Last week I got around to checking the maintenance records and learned they were installed 25,000 miles ago. I put 2100 miles on it last year, and prefer to keep it for utility purposes. It only has 83,000 on the clock, and is is pretty good shape. I will agree that the new plugs have had a dramatic affect on accelleration in all five gears. I wonder how often you change plugs in terms of miles driven.
George
Re: Frequency Of Spark Plug Change-OT
Dan Donaldson
>Depends on the vehicle and type of plugs. The recommended interval on my trucks is 100,000 miles.
Age too...
John in New Mexico
>My older vehicles never really seemed to wear them out, but I've got a '95 Saturn (yes, thats the "new" car) that has always done what you describe. I get around 30k out of a set, but thats just a guess.
John
Don Pierson
>You might think about changing the spark plug wires also. A lot of vehicles have "carbon" wires that break down after a few years with the high voltage ignition systems...just my 2 cents...I am NOT a mechanic!
Dale Lenz
Dale Lenz
>My work truck, AKA company truck is a 95-96 Chevy 1/2 ton, has 81K on it. Still has the original plugs and wires. My way of thinking, when performance/gas mileage drops, new plug/wire is a good beginning point. My son, the Ford Mech. says: if you wait until you start having problems, you have carbon-ed up the engine somewhat. Of course, he gets paid for changing plugs and things. Not that he's trying to get money, but that the way he's been taught. Like changing oil, have not heard a really GOOD answer.
Dale, AKA: Hard Sale
Re: depends
Grant Smith
>The auto makers tout their vehicles as needing plugs changed at 100,000 miles. My mechanic buddy scoffs at this because most of these vehicles have aluminum heads. IF you wait 100K miles, you may not get the plugs out to change them without helicoiling the hole afterwards. Indeed some of the manuals even suggest removing the plugs, applying anti sieze and reinstalling them. All of this is the platinum tipped plugs. What would be the benefit of using extended life plugs if you have to go through the motions at 50K anyway?
So then my mechanic buddy tells me to get rid of the plugs on my 03 Chevy pickup and install regular plugs. He said regular plugs can help you get better gas mileage and improved performance. He added that the platinum tipped plugs are good for one thing: longevity. So if you have a vehicle that is hard to get to the plugs on, then consider using the platinum tipped plugs. Otherwise, he recommends regular plugs form Denso or NGK. I can change plugs on my Silverado in about 20 minutes total...easy cheesy.
I haven't noticed improved gas mileage with the regular plugs, but then I don't really watch it that closely anyway.
FWIW, second hand info from a career mechanic.
Grant in Iowa
Ron Hildreth, Alta, Iowa
>George and Dale,
My recent experience tells me that Don is right on. My '95 5.7liter GMC half ton was getting sluggish too. Took it in to have the plugs changed and an oil change. My mechanic showed me the old plugs--they were bad, and told me to drive it but thought I also needed plug wires. He was right-hardly any change in performance I took it back the next day, had the wires replaced, and thought I was driving someone else's truck. Made a huge difference! This truck has over 135k on it. This is the same one, if you remember, that I had repainted last year, and is already starting to rust again!!
Ron in Iowa
DB
>To determine how often to change the plugs you need a good shop manual that will tell you how to read the plugs. The plugs will tell you just how good the engine is running before there is any symptoms that there is anything.
Is the engine running too rich, or lean? Is the engine burning any oil? Is the engine running too hot or not getting hot enough? Just a sampling of the problems that the plugs can tell you about. Even though the recomended change interval is up to 100,000 miles it would be wise to at least check the plugs more often. Every year would be helpful more often as milage increases.
Bill White
>Ya gotta quit usin' shellac on those auto paint jobs. Go to spar and you won't have those probs.
My humor for the day.
Bill
