Sharpening station finishing question
wilbur
>I'm getting close to completing a small worktable made from 2x material that will be a dedicated sharpening station. I expect that the top of the table will get some water spilled on it, since I use waterstones. Not a lot, since I have a pond that I built, but enough that I would want a finish that will stand up to water. Based on my past sharpening experiences, I expect to leave small puddles on the tabletop, which I would wipe up.
Will Waterlox original sealer/finish be good enough for this purpose? I ask because this is what I have on hand. It is called Waterlox, after all. :@)
Re: Sharpening station finishing question
I Cringe When I Think of My Own Experience
>Good Afternoon Wilbur,
My finishing station is somewhat less elaborate, but I dealt with the same concerns, recognizing water was going to get apilled on the finish. I chose oil based poly and put on several coats: sufficuent in my mind to protect against stray water drops and wayward lakes on the table top. I discovered that water wasn't my main concern. The slurry contained abrasive particles, and over time these wore away the finish, and it was awful enough to make me cringe every time I bent over the top to sharpen my tools. You might say it was "the slurry with the cringe on top".
George
Re: I Cringe When I Think of My Own Experience
Bill White
>George, ya ought to be ashamed (HE HE HE).
>I used marble tiles on my sharpening station. Glue down and grout and you have a nice hard flat durable surface with no worries about spilling water or oil. I put a small sink hole in the center and it is not a large area so it didn't cost much to do.
Re:I used melamine
Ron Hildreth, Alta, Iowa
Re: Sharpening station finishing question *LINK*
Jim Dillon
>Wilber,
I've had luck with "cafeteria trays" under my sharpening stones (as well as under our dogs water dish 8-))to contain water spillage. They come in various sizes and colors and materials. My stones came in a storage box that has rubber feet on it, so no slippage on the tray. A piece of under-carpet non-slip mat would also keep the stone in place. Here is a link from a source that I have had good service from. Good luck.
Jim
Plastic Trays
Ray Binnicker
>Hey Wilbur
A friend gave me some scrap (to him it was scrap) IPE that he got from a company that overhauls flat-bed trailers and uses IPE for the trailer beds. I glued up enough to make the top for my sharpening bench (20" x 30" x 2"). I did put several coats of Danish oil on it; I don't know why but I did. It has served, and continues to serve me well.
Ray Binnicker
WilbUr, not WilbEr. I apologize and will get glas
Jim Dillon
George, you have officially exceeded yourself!
