Euro-style sliding table saws
Andy Lincoln,In Dearborn MI
>Hi All,
The shop where I make most of my yearly income has purchased and installed a Format 4 sliding table saw.Most of us at the shop have very little experience with this type of saw.I am in the process of contacting Felder/Format on getting a couple DVD's they have on their saws,one of which stars Frank Klausz.I am trying to educate myself on the proper usage of these types of saws and have a head start into the season.Currently I am not working there and do not have daily access to learn via trial and error.I own The TableSaw Book By Kelly Mehler and have read the latest article in PWW,but looking for more of a how to than why type info.I should add that the vast majority of our work will be sheet goods and not lumber.I am skeptical(for lack of a better word) of the saw because the crosscut fence is forward of the blade,you are pushing the material to the fence and then trhu the blade,potentially fighting the blade pulling/pushing the material away from the blade. Also there is a bar that is attached to the sliding mechanism that "traps" a worker between the sheet good to be cut and the end of the slider.It just doesn't seem right to me but wanted some advice/tips/etc. before dismissing the potential of the saw.I MAY be able to get some pics within a week or two to maybe further explain my thoughts.
Thanks,
Andy
Re: Euro-style sliding table saws
Art Liebeskind
>Hi Andy, I have owned and used two models of the saw mentioned. A Felder which is the "little brothere" of the Format you are getting and a MiniMax. After about two days you will think you died and went to heaven. The slider makes perfect cuts painless. The long crosscutt fence CAN be mounted at the back so it works as a conventional(but huge) miter gage. You will find that it is more accurate and easier if your forward motion holds the material against that cross bar.You are never trapped by the mechanism. The use of a Riving knife (splitter if you wish)almost completely eliminates kickback. Also the cuts can be made very easily with the blade guard in place and it really collects the sawdust. Give it a chance and I guarantee you will love the way these saws work.
Art Liebeskind
PS The DVD's are useful but expect a day or two to get used to the new way of work.
Common setup - far better than what you're used to
Andrew F in Australia
>Hi Andy,
I must admit to not reading Art Liebeskind's reply, but I'm sure that it could be similar to this.
The fence away from you is far better - it avoids the pivoting problem where the stock jams and then pivots on the fence occasionally.
You currently have to pull the stock hard onto the fence and then push the whole lot through a blade.
Doesn't it seem better to push the stock onto the crosscut fence and then push the lot through the blade at a controlled speed? Also means that you're not working around a fence - I'm used to fences 2.8m long, which are a bit of a pain.
The stops on the fence are a godsend and make sizing stock quick and repeatable.
Get used to setting the rip fence a trifle forward of the saw arbor. Another common usage technique. The only time the fence is set long is if you're squaring up a panel off the rip fence and the thing's about as wide as it is long.
The fence also has a high and a low setting, the low setting for access if you're ripping narrow strips (so that you can get pushsticks into it) and also if the blade is canted.
I've got a Euro style slider with the fence behind the stock. It's a pain after what I'm used to but I've learnt to live with it. Definitely the less preferred option.
I'm not sure of what you mean by the bar that traps you in the firing line. The European saws (as they're known in the US) or a panel saw (elsewhere,) can and do kick back. Don't put yourself in the firing line.
Look to the British version of your OSHA - www.hse.gov.au and do a search on woodworking or 'circular saw' There's a whole stack of pamphlets that summarise the working of equipment in a safe manner.
Well worth a look.
Trust that this helps.
Cheers,
Andrew
Bob Lang
>As others have mentioned, the fence position on the sliding table is a good thing-you're not working against yourself pulling material against the fence while pushing through the blade. Using the stop on the fence holds material firmly, so there isn't any "fighting the blade". When you're cutting sheet goods into parts you can do almost all the work from the sliding table, after a day or so you should find this easier and more accurate.
The handle you mention is used to return the table after making a long cut. On the sliders I've used, the position of this handle is adjustable. If you don't like where it is you can move it anywhere along the length of the table. Positioning it directly behind you allows you to return the sliding table by bumping it with you hip.
Bob Lang
Paul Dwight
>Several of the regular posters at www.sawmillcreek.org own euro-style sliding table saws. There have been several long and detailed discussions about the advantages of the euro design as compared with the U.S.-style saws. If you have a chance, surf over there and search the archives. -- Paul
Sgian Dubh
>Andy, if you're comparing a typical American style cabinet saw against any of the good quality European sliding table saws for panel processing then, within half a day of using your new Felder, you'll work out that the US style machine has always been, and always will, complete and utter pants at the job.
I've been using sliding table saws since the 1970's, both small and large, and there's little to beat them for general purpose panel handling, and Felder do make a good mid level version-- not up to Martin or Altendorf standards, but still very good.
Your US style cabinet saw, assuming your company has one and hangs on to it, will rapidly change its role within the business to doing the only two things US style cabinet saws are good at-- even with those long kick-back inducing rip fences, ie, ripping solid wood and spinning those dodgy dado blades that are so popular in the US, ha, ha. Slainte.
two clarifications. *LINK*
>The 2.8m long fence is fine to work with, just a pain if it was between you and the panel. You'd have to lift the panel over it or walk around it constantly.
The website is www.hse.gov.uk (not ....... .au)
Cheers,
Andrew
http://www.hse.gov.uk/pubns/woodindx.htm
