I am installing the metal ductwork for my dust collection system. I have noticed that ALL blastgates (regardless of vendor) seem to fit very loose in the appropriate sized pipe (e.g. 5" pipe with 5" blastgate=very loose fit).
What gives? Are there any good ideas regarding how to create a tight fit - ideally without spending more $$$ on an already expensive solution.
Dust collection cyclone + metal ductwork = Good lungs and NO $$$ left. Marriage at risk - help! ;-)
>Talking with my buddy this evening, as he was reinstalling his Oneida. He has a crimping tool for making the metal pipe smaller to slip fit into the next fitting. I have no idea what one costs, but I would bet a good hardware supplier, or sheet metal shop would know.
>heating and cooling contractor and talked them out of a couple rolls of the silver duct tape. The pros use heavier tape than you can get at a borg store.
>I have used all of the above; Crimping tool, caulk, duct tape and foil tape.
I most cases I ripped a narrow strip of regular cloth duct tape and wrapped it around the male fitting on the blast gates and then put the pipe over that.
I used a mix of pipe on mine, some metal and some plastic. On the plastic pipe (thin wall schedule 35 Sewer & Drain PVC, AKA SCD 35 S & D) I cut slits into the end of the pipe about 3/4 or 1" and then used a hose clamp to compress the ends of the pipe onto the fitting. I tried cutting the finger on the bandsaw, but it took the small pieces away from=m me and through them around the shop at enormous speed (BAD Bandsaw, BAD). So on most of them I cut the slots with a jig saw and a metal cutting blade. Worked better. Cut slot about an inch apart.
On metal pipe you could cut fingers on the end with tin snips and then compress them.
The duct tape was supposed to be a filler and gasket. Not so good. The pressure of the clamp tends to cause the glue to turn liquid and the joints ooze apart. Did not want to put screws into the joints though because thy would provide a place for stuff to snag and block the pipe on the inside. If you "must" have screws, use short ones and put them in from the top.
One of mine fit so poorly I wrapped the male end oft eh gate with electrical wire and then clamped the fitting.
>If you run your screw into the fitting and get the clamping effect you want, you can run the screw back out, grind off most of the threads and run it back in. Less likely to snag stuff, although I've used 1/2 and 3/4 screws on metal DC ductwork and never found anything snagged on them. Guess most of my planer and jointer chips are too small to snag on anything anyway.
>I'd advise against duck tape. It will desintegrate over time. For just a little more get the foil tpe used by HVAC installers. It is very sticky and will outlast the pipe. It is available at most hardware stores as well as the big box stores.
>At first I tried clamps and calk but the first clog was a nightmare. From then on I empty the vac and filter more than needed to compensate for any small leaks. After that last bandsaw fire that got into the vac someone had a couple weeks ago I figure thats not a bad idea anyway.
