THE WOODRAT IS BACK!
Ideas for Bowed Plywood...(Long, but please help)
Rob Hix - King George, VA
>Hey all,
Another problem with this bookcase commission. The plywood is actually bowed a little. Ok, a lot. I had to purchase Chinese plywood, and this was supposed to be the good stuff. I know several of my sides are going to be bowed. However, I was not expecting it to be as bad as it is. Ok, here it goes, it is about 3/8" out of flat over about 58". I know I have probably cause some of it from letting it sit supported by two points over about 5 feet apart for a couple of weeks while finishing them. I DO NOT HAVE TIME TO TURN THEM OVER AND TRY TO STRAIGHTEN THEM. This has to be done another way.
First, I put the back in and applied enough pressure with a clamp to take the bow out. the pressure needed was minimal. In fact, I could still move the clamp around. The back is 1/4" plywood. The back sits in a 1/4" wide 3/8" rabbett on the back of each side. I plan on stapling the back to the sides with a staple about every 2 or 3 inches. I am a little concerned about the back being able to take the pressure of the bowed side. I am afraid bad things will start to happen.
The face frames will help to take care of the pressure a little. I am wondering if I should also put a pine frame of sorts around the back of the shelf to hold things together a little better. These are built in shelves, and because of the install method, I could easily make that back frame to back up the face frames and the plywood back.
What do you all think? Will the back be enough or should I back it up? I also plan on placing some blocks between the individual units on install that should help a little.
Sorry so long, but thanks for the help,
Rob Hix
Re: Ideas for Bowed Plywood...(Long, but please help)
les winter
>Hi Rob.
I bought a few sheets of Home Depot 3/4" oak ply for book cases and had the same problem. I screwed and glued the middle shelf into the sides using pocket screws and pulled the bowed out sides in straight.
Easy on the torque or you will run the pocket screw right out the side.
regards
Les
>Les,
The middle shelf is in. There is a 60" span from the middle shelf to the top. The only plans right now are for a face frame and a back. One or both of them has to do unless I build an additional frame for the back.
Thanks for the reply,
Rob
David Hay @ Denver
>Rob,
When I was building the cabinets for our family room, I had to deal with some slightly bowed plywood as well (left it standing on end against a wall for too long). Assembling the case helped pull out some of the curve. The face frame helped quite a bit as well. However, I also had the advantage that I was attaching multiple cases together, so simply screwing the cases together took out any remaining curve.
I would imagine that straightening with the face frame will help quite a bit...you could also put a metal strap across the back if you're concerned about the back not being strong enough to keep the sides straight.
Hope that helps!
David
Back?
>Can you use a substantial back, such as 1/2" plywood, and glue/screw it to the sides? If the back is square and straight it should hold the sides in at the back side. 3/8" is not a huge amount to straighten out with a strong back if you attach it well to the sides with a 3/8" rabbet.
If you use pocket screws on the back-side of the back, you may get added strength to hold it in place but using pocket hole screws with a rabbet is risky in my opinion and not likely to work well. My past experience trying this was a failure because the pocket screws needed more wood that the rabbet allowed.
Another option is to make a "feature" on the back edge with some kind of frame which holds the plywood back strongly. Some molding could hide it if your design allows.
Kneale Brownson in sunny N. MI
>Can you add glue to the staples? I'd think the 1/4 inch ply would be able to hold the sides square at the back if you glue, staple and clamp until cured. The addition of a square face frame should be able to take the rest of the bow out of the sides. Might be a good idea to use clamps in place of the face frame while the back does its job and then add the face frame.
1/2" back
>I agree that a 1/4" back would be strong enough to hold the bow in, but the 1/2" back has a significant amount more glue area and is easier to staple or screw into the sides. It is also significantly more rigid which I believe will also help.
My concern is that the 1/4" back may not hold onto the sides.
