How does this Walnut Desk Open?
Alan Young
>My sister e-mailed me these pictures of an old Walnut Writing Desk. I can't tell ow the writing base folds/moves into closed position.
Any insight?
Alan
Alan Young
Any insight?
Alan
It just slides back.
Rick Christopherson
Alan Young
>So you are saying the writing surface slides underneath the back case work? It looks to me like it's on a plane that would cause it to hit the letter slots and the drawer.
But that must be it..
Thanks
Alan
A fun piece to reproduce some day.
Re: ??
Bob Lemon
>Alan, My guess is that there is probably a spring in the back holding the writing desk up. Try pushing down on he back and slide it back into the case. Looks like a really neat desk! Bob
Re: ??
>It looks to me like there is just enough clearance under the pigeon hole insert for the writing surface to slide underneath. That is how I would build it anyway; no sense in making it more complicated than it has to be. This could be a pretty nice nice desk for a laptop.
Re: Notice the j shaped slots in the sides?
Al Crandall (N.E. of Indy)
>Just above the writing surface there are slots in the sides visible if you zoom in on the photo. To close, it looks like you would lift the front edge of the writing surface to move the support pins through the short leg of the "j" and then push the now leveled surface back under the pigeon holes. Then fold forward the front half of the top and allow the front of the desk to hang vertical.
Re: ??
Rick Christopherson
>The bottom of the cubby holes is only 1/4 inch thick. The writing surface just slides straight back under it. There is nothing elaborate to the tracks, and you can see the slight gap between the cubby holes and the writing surface toward the mid-left of the top.
Re: How does this Walnut Desk Open?
del schisler
>look's like the 2 knobs in frount you pull them down This open's the frount Their must be a pionio hinge that hold the frount to the write-ing part Than flop the top back And the 2 hand pull's that are cut in the sliding part Or where you write is used to pull the write-ing part out This slides under the pigeon holes If this makes sence I belive it to work that way Nice desk
>Front panel (with false drawerfronts) is hinged at the top to fold flat when the front portion of the top is lifted and flipped back. The two siderail carriers pull out and the desk surface rides on a ledger strip on each side. Does not look like the desktop and siderails are joined to move as a unit, but can't really tell from the pic.
Post a pic of your repro!!
mm
DB
>I think that it just slides straight in and out. Can not tell for sure but the writing surface looks like it may have metal drawer slides on the sides (could be Blum's). Hard to tell from my monitor and it also does not look like there is enough clearence for the slides, but the only way to be sure is to look for your self or get better pictures.
