Frame and Panel Headboard
Gordon Milliken
>Hi,
I'm new to the message board, but know many of you from articles, and other forums on the web - - and need some advice:
I'm making my son/fiance a queen size walnut frame and panel bed for a wedding present. This is the first time I've attempted anything this big, and also first time I've attempted to color wood (stain/dye) as I've always used only the color of the "clear" finish over natureal wood.
ok, here are the two issues I'm working - -
1) I'm planning three large panels across the headboard - 14 inch by 20 inch left and right, and a 24 x 20 inch panel in the center. I was thinking about using a single slab of figured walnut to create the three panels (1/2 inch?) so the figure would be continuous across the headboard (also doing a smaller version, 6 inch tall, on the footboard) - - - I know this will be really expensive - but am concerned about a solid board panel that big - wood movement? - would it be a lot smarter to use plywood, and laminate veneer if I want some neat figure? Or should it be all right to use the solid wood? I'm not too worried about cost - they only get married once....
2) My some has requested a pretty dark look - I made a sample with minwax red mahogany stain (2 coats) and he likes it ok, but wants it slightly darker, but still maintaining some of the red tone - - -sooo, am I wasting money by getting really expensive solid wood single board highly figured walnut, and then "painting" it with heavy stain?? Is there another way to develop the color without the heavy pigment?
All suggestions will be deeply appreciated
Thanks
Gordon
