dado blade size??
dado blade size??
dado blade size??
David Barr
>I'm new at wood working. Do they make a 10 inch dado blade? I have a Ryobi table saw and am suppose to use a 10 inch blade with it.
thanks
Re: dado blade size??
Jim Dillon
>David,
I'm not aware of a 10-inch dado blade set (can't say I've looked recently though), but even if one was sold, I probably would consider the much more common 6 or 8-inch variety - especially if you have a contractor saw. The choice is much greater, and keep in mind that you normally are making fairly shallow cuts in the piece you are cutting, unlike a normal 10 inch TS blade. So you don't need the cutting capacity of a 10 incher. Good luck.
Jim
DB
>When using a dado set on any table saw you need to use one that has a smaller diameter than the maxiumum size of blade the saw will accomidate. This is because the dado set needs more power to cut than the standard blade.
I also do not think that your Ryobi saw will accomidate a dado set, but I might be wrong here. Check your owners manual to find out for sure.
>Many dado sets are available in the 8" variety (and smaller). I can't recall of any larger ones.
You will also need a dado insert plate to fit your saw which will accommodate dado blades. If one is not commercially available, you'll have to make one or find a blank one which will fit your Ryobi.
Scott Whiting - Glendale, AZ
>Dado sets are indeed available readily up through 12". Some of the 8" and all of the 10-12" come with 1" or 30mm bores. Most commercial users run 8" dado sets on 10" saws and many users of lighter duty saws like yours run 6" in a stack or a 7" wobble.
Scott
Scott's Sharpening
Charles Sharp
>Is the arbor on your saw long enough for a dado set?
Here's a link to a Delta 6" dado set for $29: http://www.tools-plus.com/delta-35-530.html
I have never made a dado over 1/2" deep, so I don't really see the need for large dado set. Also a larger set requires more HP to run and I don't think your saw would be able to perform well with a larger set.
Bart Goldberg
Bart Goldberg
>While your Royobi may accept an 10" dado set, I have never found the need for a dado set that large. Most dados are usually in the under 1" depth. Thus, an 8" or even a 6" dado set will most likely do everything you need it to. Also consider that the smaller sets cost less and are cheaper to get resharpened.
My 2 cents
Bart
Re: dado blade size?? Thanks All for your Adivce!!
David Barr
KevinJ
>I have a Ryobi BTS21 Portable Table Saw. I e-mailed them to find out the specs on a Dado blade and received the following information:
Ryobi currently has a 6" stack dado blade set #4650306 on the market. The set can be ordered through your nearest Home Depots special orders desk. Recommended requirements for using other brand dado blades are as follows.
Maximum diameter 6-1/2"
Maximum width of cut 13/16"
rated for at least 4,800 rpm
Some brand names that manufacture dado blades that meet these requirements are Oldham, Vermont American, Freud, and Craftsman.
Jim Dillon
>Kevin,
Thanks for getting back to us with what you found out from Ryobi. Just make sure the arbor hole size matches what you need for your portable saw. Otherwise, you should be just fine with whatever brand you decide on.
Jim
jtay
>I own a custom woodworking shop doing mostly furniture and some high end cabinetry. I have a twelve inch Grizzly Cabinet Saw with a 1 phase 5hp motor. I use a Freud 12" X 1" arbor stacked dado set
with excellent results. It is very useful for tenons with the Table Saw Tenoning Jig. Many of the tenons I cut are over 4" in length and the dado cutter makes it very simple to do a single setup and then cut all the tenons with only slight adjustments to the tenoning jig. I would not recommend using this type of setup on a portable table saw however. I have a Porter Cable Contractor Saw that I use as a job site saw on the rare occasions that I need one and I do not think the thing would carry a dado cutter of any kind effectively.
I think I would recommend using a router with a dado bit. Good luck with it, whatever your choice.
