Eucalyptus wood
Eucalyptus wood
Eucalyptus wood
Rob Stokes in North Vancouver
>An arbourist is taking down a Eucalyptus tree tomorrow and wants to know if there's any value in the wood. I've heard of turners using it, but this is a 2' diam trunk with a fair bit of flat wood in it. Anyone have any thoughts?
Rob
Re: Eucalyptus wood
Re: Eucalyptus wood
NickB
>There are a bunch of species of eucalyptus, so the answer will depend on the exact species, but if it is the same as the stuff that is all over the San Francisco bay area, then no. It's not even good for firewood.
Hope this helps,
Nick
Re: Eucalyptus wood
Definitely useful
Andrew F in Australia
>Hi Rob,
It's definitely useable. As a rule, make sure it's quarter cut and dried slowly. You'll find it similar to hard maple, but splintery. Sticker it well when drying.
The above are generalisations that hold true for most eucalypts. It all depends upon which of the thousand or so species you're looking at.
Cheers,
Andrew
Re: Eucalyptus wood
In my limited experience, its ok wood...
John in New Mexico
>Of course I've only used the plantation stuff from Weyerhaeuser. Its super heavy and hard, but it looks great and finishes well with oils. Scraps make good jig parts too, I just made a router fence out of some and once waxed stuff just slides right along.
I've read that its hard to dry, tending to warp a lot. The only other real downside I know of is the splinters.
John
Re: Eucalyptus wood
Lyptus
JKJ in East TN
>>...I've only used the plantation stuff from Weyerhaeuser...
Same here - the photo below is a bowl I made from Lyptus. Very hard and tough but works well with sharp tools. I understand this cultivated wood is a cross between several variaties of eucalyptus.
Re: Eucalyptus wood
Very nice!
John in New Mexico
>Looks like it takes a heck of a polish!
I built our front door out of it, and my only complaint is that water in the pores turns black, so I should have used a real penetrating finish as an undercoat. Still, even that looks ok, since the door is intended to have a old look.
John
Re: Eucalyptus wood
Re: Definitely useful
>Thanks Andrew. We're not sure what species this is, not that it would matter anyways. Most of the reading I did on it indicated that the wood can be a bear to kiln dry and that it has a lot of internal stress in it.
This tree is approx 2' diameter and is growing in West Vancouver (BC) of all places. The arbourist is bringing it down today and he's going to rip a piece of it to see what it looks like inside. If it calls to him, I may well end up with a couple of 8' logs on my front yard for milling. If not, it'll go into the firewood bin. Unfortunately I'm at his mercy as there was no way I could schedule myself to go out there with such little notice.
Rob
Re: Eucalyptus wood
Re: In my limited experience, its ok wood...
>John - this sounds lie Lyptus, not Eucalyptus. Lyptus is a hybrid tree "designed" by Warehauser to be used as a pulp tree and as a source for cheap hardwood. I don't think they consider the experiment a success as you don't hear much about the wood anymore. Still, it's a decent wood that always looks good but never takes over.
Rob
Re: Eucalyptus wood
Re: Eucalyptus wood
>Thanks Nick - that matches my (limited) research as well.
Rob
Re: Eucalyptus wood
Re: What we have in the SF Bay Area
Glenn Madsen near San Francisco
>is Blue Gum Eucalyptus. An Aussie import, brought over 150(?) years ago for use with putting in the railroads, it proved pretty useless for that purpose.
If you're going to try to use it, know that as it dries, it gets like iron, and wants to twist radially pretty hard. At least, that's what mine did. Cut it green, and don't try to split it dry. It WILL burn. It was one of the main fuel sources in the Oakland Hills fire 15 years or so ago, and it has, to a great degree, regrown from the rootstock.
Some of the local turners try to make stuff of it here. Some of those guys will try anything.
It grows well along golf courses, by the way...
Re: Eucalyptus wood
>HI Rob,
As a species (and there are exceptions) it's got a high tangential to radial shrinkage ratio, so quarter cut is required to get stable material.
Don't go over 2" wide as you'll get shrinkage cracks
It's still available in crown cut (US back cut??? slash cut???) forms but it moves a bit with humidity.
The Lyptus wood that's sold is a hybrid of a construction grade eucalypt that looks good but is full of gum vein and another from E Timor that grows quickly without gum vein. More power to them, I suppose.
As far as the gripes with splinters, all the wood I work does this so I don't know any different.
If you're routing cross grain and this one turns out to be one of the more fragile ones, mark the edges of the trench/rebate with a knife or a cutting gauge to stop the splinters at the edge of the cut.
Good luck. As I said, dry it slowly and preferably quarter cut, although crown cut can have some nice figure.
If you put up a picture of the tree/leaves, (and maybe of the wood) I'll try to identify it for you. Disclaimer: I'm not a botanist, I just grew up having to recognise the major species as some burn better than others and we all had wood fires in the bush with 15F minima during winter regularly.)
Cheers,
Andrew
