>I'm building a pair of night stands with 3/4" walnut tops. The underside of the overhang is a 2" bevel at 12 degrees. I'm using a vertical sliding jig on my tablesaw fence. The fence is moved to the right of the blade, and the blade is tilted right to the 12 degree angle.
What is the best blade for this kind of cut? I tried it with a 50-tooth combination blade and got ok results. Any suggestions would be welcome.
>I haven't done walnut. I've only done maple (hard and soft), cherry and makore with my set up.
First I tried a 50 tooth combination blade (Dewalt). That worked okay - I then cleaned up the bevels with a low angle block plane. A friend recommended the Freud "Fusion" I tried it. It seems to produce better cuts - but this was on maple and I've only tried in once. YMMV.
>The blade you used should do a good job, if--- When cutting hardwoods at an angle once you start the cut you must continue the cut at a steady pace with no hesitations or stops. Both will cause burning on the cut and sometimes even a wobble in blade that will result in a very heavy cut mark.Sometimes a paintable silicon spray sprayed on the blade will make the cut easier. If you do get a burn or heavy cut, I prefer a scraper to remove them.
>I use a thin kerf blade because my saw isn't very powerful. Then I clean up with either a scraper, low angle block plane or belt sander depending on how bad the saw marks are and the shape of my bevel. If I left a shoulder the belt sander is out.
>Thanks for the input. Even the cut that goes across the board is a kind of rip cut, I think. I would seem that a rip blade might have an advantage. But I am not sure.
>If'n 'twuz me, I'd be changin blades for the rip and cross-cuts. 40T Systi for the rip and the coated Freud Ultimate x for the cross. I'd also do the cross cuts first.
I'd also be very very very clear that my fence/support was nonmovable and at least 50% as high as the workpiece's longest dimension. BTDT
>I just beveled the under side of the top for the hunt board I am working on. The angle on my rips were about 30 degrees, but the cross cuts were much less (I did not look). The wood was heart pine.
I use a temporary fence About 18" tall and five feet long. (a piece of OSB screwed to the fence.)
My blade is a Forrest Wood Worker Two. Worked very well. I have used the same blade on walnut bevels and it worked well on that too.
Mark is correct about the order of the cuts. Cut the end grain first. I got some minor splintering on mine and may go back and take another 1/32" off to clean it up. My cuts were in quarter sawn heart pine that is full of pitch and it will splinter if you just show it which blade you are thinking about.
I used magnetic fingerbaords to keep the bottom edge tight to the fence. The piece I cut is about 20 by 50".
I also like to use the table saw to cut a cove under the bottom edge of tops. I think I like the long shallow cove better than the bevel. I clean those up with a curved card scraper and a ROS.
I'll clean my bevels with a card scraper and a ROS, also.
There is a picture of my top down below about ten posts.
I agree with Ken and Jim that once you start the cut, try to continue at a uniform (not slow, not fast) rate with no hesitation or you risk the chance of burning the wood which is far harder IMO to get rid of than shallow blade marks in the wood. I would then clean up the cut with a scraper and/or ROS. If you have it handy, the suggestion by Ken to use a spray coat on the blade can't hurt. I guess I would lean in the direction of a rip-type blade to minimize burning. Good luck.
>... regarding the cleanup of the blade marks. Sometimes a ROS can be difficult to control (at least in my hands), so you might want to try sanding by hand using a cork or wood block to minimize rounding over the edges of your bevel. If you do want a rounded over look, sanding by hand would also give you better control.
