OT - Networking a Printer
Pete Stahl
>I have 3 computers, A PC with Win 2000, A PC with Win XP Pro and a laptop with XP Home (I think). I have the printer connected to the Win 2000 PC and I tried to Network the Printer but the XP computers don't see it. Is there a way to have it on the Network without have the PC's on and being able to print from the Laptop. The laptop is the only wireless computer of the three.
thanks, Pete
Re: OT - Networking a Printer
Bill Howatt
>You should be able to print from the laptop with only the W2000 printer which is hosting the printer turned on. Of course, if you have a router or a switch it must be on as well.
Normally, when other computers don't see a networked device it often is caused by incorrect firewall settings and you also need to have File and Print sharing enabled in Windows.
Momentarily disable the firewall and see if that fixes it. If you are going to get in a sweat about no firewall running, turn off the modem or unplug the phone/cable line; personally, I wouldn't bother.
Bill
Denis Ch�nard, Orl�ans, Ont.
>I seem to remember that XP Home would not "see" Win2000 domains, don't know if that applies here, though. XP Pro did not have that limitation.
My (wired) router has a printer port, so I can print without having other machines on. It's not perfect (you have less control over the printer than through a direct connection), but it works for me.
DC
Depends
Dan Donaldson
>Is the printer network ready? If so, then you should be able to put it on the network directly and all of the computers should be able to see it. If not, then there are a few options. You can put it on one of the wired computers and set it to share. This should enable the other computers to use it, but the host computer will have to be on for it to work. Another option is to buy a small print server. This is a box that connects to the printer, then to the network and enables the printer to be shared. The third option, and the one I would probably take is to replace the printer with one that has the network built in.
I am not sure about other brands, but the HP printers that are network enabled have an installation disk that sets it up on each computer to enable them to share it.
I have an HP 6840 that is on the network and I can print to it from my Windows box, the Linux box, and my daughters Apple laptop.
Ron in Drums PA
>No, you need the PC that has the printer to be powered up.
BTW Don't click on this http://tinyurl.com/2musyj
I agree with Dan
Curt Harms
>I had a laser printer networked with a Netgear print server. It worked mostly OK most of the time. W2K boxes sometimes wouldn't see the printer and I had to go "find" the print server again. I got a Brother laser MFD that was network aware out of the box. Like Dan's experience with H.P., plug everything in, insert the CD in each computer and you're in business. Mine has a cable running from the router to the printer; there are now wireless printers as well.
Perhaps the coolest thing to me was being able to scan from each computer. Being able to scan to PDF has been useful on several occasions. Also for anyone who only has inkjet, laser is a LOT cheaper per page. I have an inkjet in case I need to do color, but for 90% of what I do B/W laser is just fine.
HTH
Curt
Thanks for all the ....
Pete Stahl
>responses so far, any more ideas please post them. I tried messing with the firewalls and made sure everyone was sharing. I have trouble sharing files between them sometimes too. I'll check my printer and wireless modem when I get a chance to see if I can connect the printer directly to it. I think the modem may handle now that I looked it up (Linksys WRT54G) but not sure about my HP printer. If I get it to work I post it back here.
ChrisR
>Have you installed the software for your printer on each of the computers? Also have you setup sharing for this printer?
John McGaw
>My response is that one should _never_ use MS's printer sharing. It isn't worth the aggravation. If your printer isn't network compatible, spend a bit of money and buy a small print server. If it is, hook it directly to the network. If your printer is old enough to have a Centronics cable connector I can vouch for the quality of the Netgear PS101 server. But there are small servers which work with USB printers and variations for both wired and (ugh!) wireless networks.
Pete Stahl
>Chris,
No I don't think I did on the other PC's. Thought windows covered most of them. I did set up sharing for this printer. I can print from The XP and the 2000 PC but not from the Laptop. Thanks for the reply.
Pete Stahl
>John,
I have a HP PSC 2350 printer which is connected to a USB port on the 2000 PC. I was thinking of going the printer server route but I'm working 12 hour shifts this weekend and tomorrow night so I don't know when I'll get time to look for one. Someone on another sight recommended a D-Link DP-301U Express EtherNetwork Fast Ethernet Print Server. Thanks for the reply.
