Re: 90 seconds on shellac...
Glenn Madsen near San Francisco
>Not Mark, but I've spread a good amount as a hobby fellow...
Shellac is an organic, comes from South East Asia and the neighborhood. It's the excretion of a beetle, which is collected and refined to various degrees, dissolved in alcohol, and laid down on wood. For many purposes, the natural wax in it needs to be removed. The shellac undergoes esterification, and so ages over a period measured in months, maybe a couple of years. Old (mixed) shellac is no bueno.
It's perhaps the most forgiving finish to use. It can be brushed, wiped, sprayed, dipped, and 11 other ways of application. What you do is up to you. It makes a great sealer or barrier coat between incompatible layers of a finishing schedule. It makes a reasonable finish by itself, and is 'better' when topped by a good furniture wax, applied and buffed with a good buffer.
It is susceptible to alcohol and other solvents, in moderation. It doesn't wear like a poly, or a hard varnish, so use it where that's not a problem. It's a great finish for a beginner, I think. That's how I learned to use it. It was SO MUCH better than anything in a yellow can I got from the hardware store.
I buy my supplies from Woodcraft, or Jeff Jewitt, unless I want to use premixed Sealcoat, which is dewaxed blond 1.5lb cut that will last in the can for a year or so. That can be had from any good hardware supplier. Watch out for the amber, which looks similar, but isn't dewaxed. That goes well on floors, etc.
Would I use shellac on a huntboard piece? Heat can be hard on it, so can alcohol, but it's easily repaired. Your call. I'd probably use a good varnish, like a Waterlox...
OK. That was two minutes. Sorry.
