Re: band saw drift
Rob Stokes in North Vancouver
>Make sure the wheels are parallel to each other in the same plane. This may require removing the lower wheel (or upper wheel) and shimming it.
When that's done, install a new blade and tension it just enough to run the saw without the blade coming off. Back off the upper and lower guides and rear bearings and put the upper guide block carrier up as far as it will go. Stand aside and fire up the saw.
Tension the blade until it stops fluttering Then go another turn on the crank. Go two if you're going to be resawing.
Use the top wheel lateral adjustment while the saw's running and center the blade on the wheel. Don't get it close, get it centered. Yes, this means the teeth may be running on the rubber wheel and yes, this means it will wear out faster. They sell new tires and they're really not that hard or costly to replace. Consider them consumable and get past it. Turn the saw off.
Pull the upper guide post back down to where you can work with it. Wrap a dollar bill around the blade and bring the rear bearing forward until it touches the bill. Lock it in place. If you have steel or ceramic guide blocks, or side bearings, bring these out until they touch the bill, making sure not to actually move the blade. Lock them in place.
If you have cool blocks, remove the bill after you do the rear bearing and set the cool blocks so they just touch the blade. If it's a bigger blade, you want to make sure they're behind the gullets of the teeth. If it's a smaller blade, "capture" the blade (including the teeth) in the cool blocks. Yes - that means they'll wear out too - just like the tires. And yes - you need to consider these consumable as well. Don't worry - they still last a long time.
The top's now done - repeat for the lower section.
Lastly, raise the post again and square the table to the blade (with the saw off). Now's a good time to adjust the table stops if needed.
Your bandsaw is now ready to go. Draw a straight line on a board so that when you cut down the line the edge of the board is right beside the miter slot. Fire the saw and cut the line. If the end of the board nearest you has to be moved to the left a bit (relative to the miter slot) to achieve a cut on the line, back off the rear guide bearings and tilt the bottom of the top wheel towards you a bit (a very little bit). Reset the bearings (using the dollar bill) and repeat the cut.
If the board has to be swung to the right as you cut it, move the bottom of the top wheel away from you.
Play with this a bit - you'll get it. When you're able to cut the line and have the board run parallel to the miter slot, you're done. Square the fence to the miter slot and rip to your hearts content.
This sounds tougher than it is. The whole thing (including the shimming) shouldn't take an hour and you'll be amazed at how easy it is to turn your bandsaw into a machine that actually has some accuracy. The whole notion of having to accept bandsaw drift is bunk. granted, some cheaper retail blades may have that tendency, but you can compensate with the saw in a matter of minutes (or less). And specific blades don't change how they behave unless they're too dull to cut with anyways. Special "drift accommodating fences" and "resaw fences" etc. that are marketed are simply gap fillers for an un-tuned saw (as many are).
Tune your saw and have it work for you - not the other way around.
Rob
