Steel City 8" "Industrial" Jointer - review (long)
>I bought a SC-40605 (Steel City Industrial 8" Industrial Jointer) a while back on the advice of various people.
I wanted a hefty machine that could take abuse and last a while. I bought it from a Steel City distributor.
The jointer came in one carton and one plywood shipping crate. The base was in the carton and the parallelogram table, fence and some other parts were in the crate. The shipping weight was about 600 lbs. I was able to load in my truck (along with other stuff).
Unloading it without the help of a forklift was a bit tricky. The carton with the base, motor and a few boxes of parts packed inside weighed in at 175 lbs or so. The shipping crate was somewhat heavy (maybe 420 lbs). It took three people to get it out of my truck (four would have been better).
I got the base down into my basement shop by myself using a heavy duty hand truck. The front wheel for the mobile base was easy to install. I opened the shipping crate for the table and removed the fence, cutterhead guard and various parts. I unbolted the table from the crate. Mike and I loaded the table onto my handtruck and tied it down for the journey around the house into the basement.
We then lifted the table onto the base and removed the plastic.
The table ways were coated with an anti-rust compound and protective paper. I cleaned them with some paper towels to get most of the compound off followed by a scrub with WD-40 and rags.
Aligning the table with the bolt holes was fairly easy. Putting in the bolts was easy except for the last two. The dust chute for the jointer stretches from the top to the end of the base. The two bolts which flank the dust chute were somewhat of a pain to put in and fasten due to the chute and the neighboring motor mount brackets. I was tempted to leave them off, but I didn't :).
The infeed and outfeed tables were aligned well with the knifes of the cutterhead. Both tables were flat (within 0.001" along the length and width). The fence is very heavy! It was fairly easy to install and align, but it is very heavy. Installing the paddle switch and cutterhead guard was very easy.
First impressions - the jointer is not as noisy as some others. Although it has only three knives, it cuts oak, poplar and cherry very well. It cut somewhat swirling grain reasonably well for straight knives. This jointer weighs in at a good 500 lbs when assembled. It is definitely a heavy piece of equipment. The dust chute connects to a 4" diameter fitting. The chips clear easily and well with my DC system. There is some minor spray of chips from the top of the cutterhead and out the back.
I am happy to have it.
Re: Steel City 8" "Industrial" Jointer - review (long)
Re: Motor mount
Re: 4" flange for hose connection
Fred West in West Chester, PA
>JL, thank you for the review. I have a Grizzly six inch and I have been eyeing eight inchers as I always seem to need just a bit more than the six gives me. I will definitely add the Steel City to my list and love the fact that it has the parallelogram like the delta 8".
Howard Norman-Prescott, AZ
>At first glance it looks like at least a cousin if not a twin of my Grizzly G0490. Should be a good tool.
Howard
Craig Daymon
>JL,
Thanks for the review. I've been looking into an 8" jointer and I'd like to get parallelagram beds. The problem, I have been told, is that the U-turn going down into my basement would make getting a jointer of that size (the parallelagram bases seem to be sustantially larger than non-parallelagram) down the stairs impossible. Any chance your stairs are similar...meaning there's still hope?
Also, do you know if Steel City offers a spiral cutter head for the 8" jointer?
Thanks,
Craig
Looks like a DJ20
Virgil
>Is this a clone?
>Sorry Craig, I have outside access to my basement (daylight basement), so I brought it around that way. The table is long (76.5") and heavy. I don't know how it would work with your stairs.
I don't know if Steel City is going to be offering a helical cutterhead, but given the interest in them, they probably will. The Steel City cutterhead is 3 3/8" in diameter, so the Byrd Shelix cutterhead for the DJ-20 may fit.
Re: Steel City was founded...
>by refugees from Delta, so it is similar.
Virgil
>What did they changed from the Delta? I hope that they took out that cavernous gap in the area between the cutternead and the fence. The gap on my dj20 was large enough that the edge of a canted 5/4 could board (did) go under it and get wedged. I had a Delta Rep tell me this was impossible to happen.
Re: No gap that large!
>I don't really see much of one at all, but then the maximum I've tried to joint was 1/16 - 1/8".
