Re: Ceiling outlets, best way to use?
Rod Peterson -- Ormond Beach
>To expand a little on part of my reply to Dan Manuturi's Unisaw plug post below: “The one inconsistency [to common plug/receptacle combinations] I exercised in my shop was in the ceiling drop I installed, on which I installed a NEMA L6-20R locking receptacle, and used a L6-20P on the short converting wire (with a 6-15R on the other end). I wanted the short cord not to fall out of the ceiling drop, but didn't care at the point two or three feet above the floor.”
I used a water tight connector on a 4" steel box cover (mounted in turn to a 4" utility box in the ceiling) to act as a strain relief for my 12 gauge rubber jacket flexible cord (bright yellow, I might add) I got from the borg. With 8' ceilings, the drop is only about 18" or so down to the first break (and thus easily reached). That's where I installed the L6-20R.
I crafted a short cord (probably around 2'—the one mentioned in the original post) with the L6-20P on one end and a 6-15R on the other, which I use to power my planer (and its factory provided 6-15P/cord combination) sitting at the right end of my Uni.
What I didn't say in the original post, however, is that most of the time I have connected an 8' or thereabouts similar cord which has another L6-20P on it, and which is routed (and cable-tied) around the back of the Uni and over to the left side to a point just behind the front fence rail. There it goes in to a 2x4" utility box and is attatched to a single 6-15R mounted in the box. The factory 6-15P that came with the saw plugs in there which gives me an easily accessible (as well as frequently used) physical disconnect for my saw Blade changes and other activities around the blade can now be done with impunity.
My shop is in what used to be a two car garage, and being a one man shop, it doesn't bother me to unplug the Uni and plug in the planer when it's time to use it. The Uni and planer sit pretty much in the middle. The ceiling drop is just about in the middle as well, and even should I make adjustments in either the saw's or the planer's position, there is still have enough flexibility in the layout to make use of the drop. If I get really ambitious and decide to locate elsewhere in the shop, it's an easy enough task to move the overhead box to another location. I left about 6' of slack in the attic against just such an eventuality.
I've never had the easy physical disconnect for my table saw before so I've stepped way up in my shop safety protocol when operating around flesh eating tools. This has worked out very well for me.
I hope this helps.
Rod
