Powermatic Model 26 Shaper.. Help!!
Rob Simon
>There's a nut under the 1" spindle that looks like it needs a special wrench or ??
How do I change out the spindle? I need to put on a 3/4" spindle and I have never changed it out..
Rob Simon
Re: Powermatic Model 26 Shaper.. Help!!
John D. Luke
>Lock the spindle (rod on right side of machine)
(I'm not in the shop right now so I can't give the wrench sizes, they should have come with the machine)
Open back of machine and, using a wrench, remove tie bolt that goes up through the spindle.
Then using a damn big wrench remove the spindle nut and spindle as a unit.
Then remove the spindle nut from this spindle and re-install on the spindle you want to use.
Install spindle, then tie bolt, shaper cutter, unlock spindle and you're good to go.
Oops forgot, unplug machine before starting to remove spindle.
