Who uses a single car garage as their shop?
Larry Shapiro, Fairfax, Va
>I currently use an unfinished portion of our basement as my shop but I may soon need more space in my houe and have to finish that. My only alternative will be to move into my single car garage. I wanted to know who uses there single car garage as a shop how it works and if you happen to have a shop tour that I could look at.
Any and all advice would be appreciated.
Thank you very much,
Larry
Re: Who uses a single car garage as their shop?
MN deepwoods (Dave)
>Good afternoon Larry,
I was married Oct '06 and moved into my (now) wife's home. My woodworking tools have moved into the single stall garage(SSG), which also includes a pre-existing dog kennel. Since that happened her car has been living in the driveway, unfortunately. She's ok with that because her kitchen is being rebuilt, and the other around-the-house project list is nearly endless. We do have a fair amount of lumber, snowblower, and lawnmower in the garage too.
I guess that means I'm curious to see how people have moved their 'shops' into a SSG, and "if" a car still fits.
Dave
David Yoho
>Larry, the shop before my current one was in a single. While I didn't own some of the power tools back then that I have now, I still found room for a RAS, drill press, lunch-box planer, small router table, contractor's style tablesaw, 6" jointer, a couple of shop vacs, 14" bandsaw, the usual assortment of hand-held power tools and clamps, and a free-standing workbench.
I found a couple of things helpful for resolving the space issue. The first thing I did was build a shed in the yard to house things like the lawn mower, yard tools, spreader, wheel barrow, etc. Another was utilizing the available overhead space. Since the garage had a ten-foot ceiling, I cobbled up a cool lumber storage rack that I attached to it. It's surprising the amount of sheet stock and solid lumber I stored up there!
Mobile tool bases are almost a must in space that's limited. I also oriented the position of my RAS and tablesaw toward the roll-up door. For those times I needed to cut longer stock, I just opened the door.
You should be able to exist and be productive in a one-car space as long as you figure out how to utilize your own space efficiently with a work triangle that suits the type of projects you'll be doing. Do what you can to find alternate storage for non-shop related things, and look for opportunities to utilize space that is often overlooked.
David
Dan Manturi
>I use half of a 2 car garage for my shop. While it is currently being reconfigured, I had it working pretty well at one time. This is sort of a hybrid - i do get to use the space where the second car resides during a project, but the power tools do not venture to that side. I do use the wall on that side for storage of hand tools.
My jointer, router table (pretty big one), and bad saw are on rollers. Wood magazine had a pretty good article many years (like maybe 1995 or 1996) ago on a garage shop and I used their system for rolling bases. It involved only 2 wheels on one side and a sort of lever with a third wheel to jack up the stationary side and roll the stuff around. Works great. There were also plans in that issue to build a folding bench where the leafs on both sides fold down, but when extended, the whole table is about 4 x 6', and is a great work table that can collapse and roll away. Hard to describe, but it works. I did have the old table saw at the garage entrance so i could handle longer stock. Jointer would roll out from the back wall and sit to the left of the table saw when I needed that. Lunchbox planers sat on a B&D workmate when i needed those. I now have a rolling stand for them.
Bottom line is that making the stands and being creative about pulling out the tools I needed, using them, rolling them away worked for me. it is a pain but becomes part of the work process. i guarantee that you will learn to get all your jointer work done prior to rolling it away, or you have to drag it out again..
You just have to get into a process mode. The only tool that did not move was the table saw, and I had THAT on wheels if it had to.
Good luck. It can be done.
Dan M.
>My shop is in a one car garage. I have a TS, BS, RAS, Jointer, Chop Saw, shaper, drill press, lathe, lunch box planer and work bench in there. The DC and Air compressor are in a closet I built outside to save space and to cut noise.
The TS Is "aimed" at the overhead door and is 16' from the blade to the rear wall and about five feet from the door. If I rip something longer than 5', I open the door. The jointer is at and angle and lines up with the entrance door from the house. If I want joint a long piece, I open the door.
The shaper, shop saw, and Ras are lined up along on wall and are all at the same height with their fences lined up, in effect creating a long work counter. The fence of the jointer serves as a support for long pieces at the RAS.
The DP, Lathe and BS are along the other long wall and the Lunch box planer is on a roll around stand and parks between the lathe and BS when not in use. Or at least it did until I bought a bed extension for the lathe. If I leave that in place I will have to cut the stand down to let the planer park under the bed extension.
I failed to mention there is a 16/32 Performax sander on a low roll around cart that parks under the wing of the TS. The wing also has a built in router station so it can share the TS fence.
The lights above the TS are positioned to shine through the windows in the overhead door when it is in the up position. The Performax and planer share a DC connection.
The BS, TS, shaper, chop saw, RAS, and Joiner have permanent hookups with the blast gates that turn the DC on when you open the gates.
I would be glad to take some pictures for you, but I would have to get one of those tiny little spy cameras with a fish eye lens. If something comes into the shop something has to leave.
Thinking it through is very important. For example, planing a long board involves it starting under the workbench, passing through the planer and going under the wing of the TS. So having things either lined up or NOT is essential.
Re: Who uses a single car garage as their shop? *LINK*
John McGaw
>Does this qualify? I built a wall down the middle of my two-car garage to contain the dust and aid in heating/cooling. I use the non-car half as my shop. It works out quite well with the proper equipment and some mobility-enhancements. There are some rather bad old photos of the shop at my website.
Garage Shop
I had to buy a new house for my hobby!
Joanne Adler in Pt. Pleasant, PA
>I used to have my shop in a single car garage. My rule started out as "I could buy anything I wanted, as long as I could still pay the bills and eat, if, when everything was put away in its space--the car would fit too." Even though I never seemed to be finished with "projects" and didn't want to bother to clean up to actually PUT the car in there, for a long time, it would really fit. I had a 6" jointer, lunchbox planer, 14" bandsaw, tablesaw, miter saw, drill press, expanding workbench that tripled as cutoff table and router table, lumber, handtools, 2 shop vacs, lawnmower and yard tools, and windsurfer in there. I even upgraded from a Bosch tablesaw to a contractor PM 64A. I think I broke the rule when I finally bought a dust collector. By then, I decided it was too dangerous with all those hoses and cords everywhere and I either had to quit the hobby or move to have a larger shop. Couldn't seem to grasp the concept of giving up the hobby. Found a house with a 40 x 25 ft. barn--oh yeah! A little more space. :-)
Re: I had to buy a new house for my hobby!
Phileas
>Hi Joanne,
What kind of floor does your barn have? And how weather tight are the doors?
Phileas, who is considering the viability of a dirt floor horse barn for a shop.
Robert R Clough - Thorncraft
>Good evening, Larry. My shop is in a former milk house which is, in turn, part of a machine shed. The building is now a 2 car garage plus a stall for the tractor, etc. The milk house part is 11 x 22 and houses a contr ts, JoinTech router table, band saw, bench, performax drum sander, delta disc/drum sander, horizontal router table, and many cabinets. I have no jointer or planer. I do much of that by hand.I forgot the bench grinder and sharpener station. The shop is also heated and air conditioned. Is it easy to work in? NO!! but it does work. If everything is arranged carefully and the process is carefully arranged, matters generally go smoothly. Then there are the other times! Luckily I am small.
If I Were Single I'd Have a Bigger Shop! *LINK*
Jim Rahbe, Bedford, TX
>Larry,
My shop is in a single car garage. You can see it by looking to the left and selecting �shop tours� or at the link below. These pics were taken several years ago. I now have a new Table Saw and Band Saw, but the basic layout is the same. Also in the shop is a 6� Jointer, Router Table, Miter Saw, Lunchbox Planner, Dust Collector and Overhead Filter.
In this space I�ve made two complete bedroom sets, a full set of Kitchen and Bath cabinets and a number of tables, etc. I can only build one thing at a time, and there is no room for wood storage, but I do have an adjoining two-car garage that I can use on a temporary basis.
I�d like something about five times as big, but if the choice is small or nothing at all, I�ll take small every time..
Jim R.
My Shop
>You can do a search for posts made by Joanne over the last few years to see the beautiful shop she has made out of that barn. Plus the jointer I am still trying to figure out how to steal. The dirt floor is a thing of great beauty, and in my opinion could work well; they tend to get hardened and polished from use. You could start by insulating and sealing off one area of the barn to use as a shop, then increase the area with time.
wilbur
>Hi Larry,
My shop, which is still in the process of being set up, is in my basement in the area just underneath a single car garage. It's 20' x 11'. Hopefully this counts. :@)
The way I have things planned out, it will house a dust collector, combo jointer/planer machine, bandsaw, drill press, lathe, sharpening bench, and workbench. I plan to put most of the storage on the walls.
What has saved me a lot of space is finding the combo jointer/planer machine, and making the decision to not get a tablesaw. This may or may not work for you.
I think I could cram in a tablesaw if I needed to, but I'm glad I'm not planning to.
>Phileas,
My �barn� is not what you�d normally think of as an �old barn�. It is not your basic red and white horse or cow barn, but a more modern structure with a concrete floor. I think the guy who built it was going to work on old cars in it. Here it is before I moved my shop in, added radiant heat (and another concrete floor), insulation, ceiling, inside walls, and restained the outside.
Moses, you come visit and just see if you can get Frank out of there! You�ll need a flatbed and 6 or 8 burly guys�it took 2 men and 2 women to get it in here. :-)
Larry shapiro, Fairfax, VA
>Hi Barry,
If you get a chance and can sneak a camera into the shop I would greatly appreciate some pictures. Your resonse as well as others show me it can be done. My garage is only 11x19 but almost everything is on wheels already. I guess I can park things in the driveway while i'm working. do you heat and cool your shop?
Thanks,
Larry
>Hi Joanne,
buying a new house was my first thought :-) But, with the cost of real estate these days I think I need to hunker down in the garage for a while!
Thanks,
Larry
>Hi John,
Thanks for the response and the pictures, do you heat and cool your garage? if so how?
How do you like the combo machine, I thought about looking into that to save space?
Thanks,
Larry
Re: If I Were Single I'd Have a Bigger Shop!
>Hi Jim,
Thanks for the reponse and the Pics, It looks like you have your shop set up very well. Can you open your Garage door or have you closed it off?
Thanks,
Larry
Thanks for all the responses
>This has been very helpful!!
Larry
Phileas
>Barn! That's a pretty nice house!
I'm sooooo jealous :)!
Thanks for the pictures,
Phileas
Dale Lenz
Re: A true barn...
Dale Lenz
>as in a hay barn with opened front. My shop is not as nice looking as most on this site but is VERY comfortable, and looks nicer on the inside than the outside, 20x42. Gotta get around to painting the rest of the outside on of these days, : ' >. Cement floor, well insulated. Insulate the heck out of it, relative cheap, if you don't count your time, : ' >. Not counting the barn structure, I've got 6K in it. The 6K is mostly all material, as I did most of the work myself. Purchased the trees/logs had them sawn up and dried myself and milled myself also. The only thing I'd do differently is buy new T-111 siding for the front siding. The siding you see was found in the barn when I cleaned it out prior to getting the floor ready for the pad. At that time, 10 years ago, new siding would of cost me 250 dollars. Speaking of the shop, gotta go play.
Then don't forget to use
>the ceiling for storage or hanging things. I built a wood rack hanging down from the ceiling in my garage shop; I didn't want to use any floor or wall space, if possible. I also had shelving or cabinets up high on the walls for stuff I didn't use all the time, to get it out of the way. That was one space where being short was actually beneficial. I could put things up high for storage and still have room for other things at my height or floor level.
Did Open, Now Doesn't
>Larry,
At the time the pictures were taken, the doors (one at each end of the garage) did open. I found doing the work a normally do, that I never had to open them. Because of this, and to make it easier to cool, I took out the doors and installed walls. Since it is against code, in this neighborhood, to do this, I made the outside look as if it were still a garage door. See pic below..
Jim R.
Jim Dillon
>Larry,
You might want to check out the book by Scott Landis called "The Workshop Book" published by Taunton Press. It has a lot of neat ideas for setting up your shop if space is limited. And it also has pics of real "dream shops" that are unbelievable as well as apartment-sized shops. With careful planning, the use of your garage is very doable. My 2-car garage has a 11 foot extension built on the end where I "try" to confine my woodworking - but it doesn't always work. Good luck.
Jim
>Jim My first shop was in an open garage with no door. I built a fold up workbench. When folded up it locked and kept what few tools I had safe. My first good shop was in the back bedroom of a 2 bedroom apartment. I covered the carpeted floor with MDF and added 2 extra layers of filters for the air return duct. I had a shopsmith and all the accessories. Even built a wood support system that attached to the shopsmith so I could cut up plywood by myself. It all stored against the wall when not in use.
I've always been tight on space so I have to be really inventive on all my storage. I now have a 2 car garage and have everything on rollers because I'm still tight on space and have to move things around when I build larger things.
I also have a club meeting at my house once a month so roll all the machines to the back and put up chairs. I have to rotate my lathe 180 degrees and it weights a 1000lbs so I had to come up with some nifty rollers for that.
David Hay @ Denver
>I currently work in an extra-deep 1-car garage size building. I say garage size, since it's not actually used as a garage (we have a 2 car garage for the vehicles). At my previous house, I worked in 1/2 of a 2 car garage without much trouble...but then I didn't have nearly as many machines as I do now. If you do nothing else, put everything on wheels. Then you can reconfigure as necessary. Also try to think in three dimensions when laying out your tools. For example, does the outfeed of your planer clear the top of your jointer? If the workbench is at or slightly lower than the tablesaw, it can be an outfeed table too. These kind of things can really make a small shop work better.
Here's an older set of pictures from my shop...
http://www.shoptours.org/shop_tours/files/david-hay.html
