TS Fence, UHMWP Plastic question?
>I have an old Rockwell Delta Contractors saw. A friend gave me some scraps of High Density Polyethylene about a half inch thick. The scraps were not flat or straight. I sawed them down to pieces about four inches wide and slightly longer than the fence and bottled them through the fence, One on each side.
One is nice and straight, but the other one has curled out a little from the fence at both ends. (1/32"+/-) I tried clamping it back to the fence and leaving it for a few days, but it just curled back out. Anyone have experience straightening This type of plastic?
I have a heat gun and was thinking of heating it and sticking it to the fence with double stick tape. Any suggestions?
Re: TS Fence, UHMWP Plastic question?
>You are on the right track. When I have had cup stock (this is the stuff that they make molded pudding and gelatin cups out of), I usually heat it in an oven with weights on it.
You are essentially doing the same thing with your heat gun and your double stick tape. You heat it to just below the softening point (about 130-140 C for UHMW HDPE) and then let it cool. This will take the stress out of it and allow it to cool in a straighter manner. You may have to heat it a couple of times.
I'd worry about the double stick tape though. The tape shouldn't be bothered by the heat, but I'm not sure about the adhesive.
knotscott
>Got a jointer? You can face joint UHMWP then plane the other side for a nice flat face on both sides.
Keith Newton
>it is a shame that the T of the fence is in the way of just running it over the jointer while it is attached to the fence.
I think I would just use a block-plane.
Maybe I don't have the right stuff????
>I have pieces of polyethylene that are translucent white. It used to be in a large 1/2" thick sheet and was used to cover snow plow blades. When they finished covering the blades, my friend gave me some scraps. This stuff is pretty rubbery (literally plastic). I think if I ran it over the jointer to face joint it, it would mostly flatten out and then spring back.
Happily, the piece I put on the left or "most used" side of the my fence remains flat. Its the one on the back side that curled.
Thanks for the ideas.
Re: Maybe I don't have the right stuff????
Larry Clinton At Frankfort (Central)., Indiana
>It might be real tough to join UHMW. That material is pretty "rubbery" and has a co-efficient of friction that is less than Teflon in some cases. Unless your knifes are razor sharp and you take a fairly deep cut the blades will just jump up and down on the surface. I have been involved in machining quite a bit of the material in my last life (Engineer before I retired). It has a tendency to machine like warm chewing gum. If you drill a hole in the stock, it has to be "on size" or quite a bit smaller as you cannot take .001 to .005" of material out of the diameter, the drill bit will not remove any material or will "grab" and remove .015 or .020 (with a brand new bit) - reamers won't work worth a hoot. Even abrasive methods - sanding - grinding, are kind of a hit or miss process. It is one of the worst materials I have ever used as far as holding machining tolerances. I would heat, clamp and bolt the material in place and hope for the best. The only way we were successful in adhesion of the material to itself was to use a hot welder (or ultrasonic welding) - almost impossible to attach it to other materials without mechanical fasteners, although I have purchased rolls of UHMW with an adhesive backing that worked fairly well. Don't know how the adhesive was applied - possible "melted" into the surface? Delrin is a little better material to work with as far as holding dimensions and flatness, but somewhat more expensive.
