OT - Weird network problem
Denis Ch�nard, Orl�ans, Ont.
>A couple days ago I could not connect to WC. I thought at first that the site was down, not long after I e-mailed a friend who told me that he had no problem connecting. We run two PCs (for each employee) here, connected on different networks. Switched to the other PC and I connected to WC immediately. I talked to our network guy here, and checking the network settings, he had me add a secondary DNS server. Problem solved. Or so I thought...
Since yesterday there's another site that refuses to load, despite the earlier fix. I'm kind of baffled here...
Again, the secondary PC has no problem connecting to the site. And, this is the only site in my bookmarks that gives me trouble. Weird...
If that makes a difference, I'm using Firefox 2 on XP Pro. I'm also using Norton Internet Security (not my choice).
Any clues?
TIA,
DC
Re: OT - Weird network problem
John McGaw
>There are occasional outages that affect certain parts of the internet but these are pretty rare and are usually widely known in short order.
Probably the easiest thing a user can do is to perform a trace route to the URL in question. In windoze that means opening a cmd window and typing something like "tracert www.somesite.com" (without the quotes) and pressing return. This will at least tell you how far you are reaching. If the system denies any knowledge of the URL it often turns out to be a DNS problem. Sometimes executing an "ipconfig /flushdns" is enough to resolve simple DNS problems.
Glenn Madsen near San Francisco
>There were some reported problems centered in the Bay Area for some major Internet hosting and transit carriers on Thursday, IIRC. May have carried on further. I had a couple of instances of not reaching WC either, quite unusual for me.
15 years ago, it was slow dialup and wonder and amazement at what we found. Today, it's a utility.
It's not your fault
>Sounds like your DNS server is the culprit. Escpecially since your IT guy added the other DNS server and it worked. I could bore you with a bunch of stuff to try to determine if it in fact a DNS server issue, but let's just say that if two computers on the same network are using two different DNS server, and it's working using one and not the other, have your IT admin do a DNS refresh to clear out the DNS cache, and that will likely fix it.
Happy Woodworking!
Well if you really want to know.....
>If you have two PC's using two different DNS servers, on each PC go to DOS and type in
NSLOOKUP [ENTER]
www.woodcentral.com[ENTER]
and you will probably see that the addresses returned are not the same. If they are and your still can't access the website, let me know.
Happy Woodworking!
