Hide Glue question?
Hide Glue question?
Hide Glue question?
>I have made some drawers 18" wide and three to four inches tall from oak and wish to attach heart pine fronts to them. The drawers are through Dovetailed and the fronts would be decorative. Would this be a good application for Hide Glue? I was thinking liquid Hide Glue and the appeal is that it is reversible with heat. Is that correct? Could I glue them on and then heat them with a heat gun and remove them if it became necessary? They are about 3/8 thick. Any other suggestions for attaching fairly thin fronts?
Re: Hide Glue question?
Re: Double stick tape & screws?
Glenn Madsen near San Francisco
Kneale Brownson in Northern MI
>Will the decorative fronts have handles? If so, the handles should serve to hold them in place. I'd use the double sided tape to test mount and the handles for permanent mount. If you're using some other opening treatment than a handle, I'd use the tape and pinnails.
pecker
>I have used a couple small dabs of construction adhesive. This allows you to get the false front aligned properly. When dry, you can add mechanical fasteners. Either small screws from behind, or let the bolts for the drawer pulls serve that purpose.
Re: Hide Glue question? *LINK*
Jim Dillon
>Morning Barry,
I've attached a few drawer fronts using Super Round Head screws from McFeely's. The head of the screw is 7/16 inch wide so you can drill a hole somewhat smaller in you real drawer front, yet large enough to allow adjustment and removal (if necessary). I suppose you could even counterbore with a forstner bit a hole large enough for the head of the screw so you wouldn't see it from above. Worked for me. Good luck.
Jim
Super Round Head Screw
Larry Clinton At Frankfort (Central)., Indiana
>Although hide glue is reversible, I think you would find it would be a real task to remove the drawer fronts. Remember hide glue holds up for centuries in hot environments without failure. IE: items from tombs in the dessert. To remove the drawer fronts would probably require not only fairly high heat, but also steam or water injected between the front and the drawer casing. I have had to drill small holes (< 1/32), & inject water into chair rungs to loosen them (even with a heat gun), when the rungs would not budge with force and "rapping". If it were real easy to "un-glue" items, it wouldn't be a very good material to use to build long lasting furniture. If you anticipate removal I would use another method as suggested in the other posts.
Thanks and......
>I am not really thinking of removing the drawer fronts, I was just trying to make the work "reversible" in case of an emergency. I want the fronts secure, but was thinking that if they cracked I would wan to get them off, preferably without dynamite.
Wonder if I can put a screw through a half inch piece into a 3/8" piece and have it hold without coming through the front?
The plans call for a single knob in the center. I am thinking of two knobs. I feel two knobs would hold the front securely and give a better "pull" on an 18" wide drawer. Might be time to post a picture and ask.
Re: Thanks and......
Jim Dillon
>Barry,
You could try cutting off the end of the screw if it was just a tad too long. Carefully drilling a pilot hole beforehand might help guide the new blunt-headed screw. I've done this on other projects and it seems to work just fine. I'd try on test pieces of wood first to get the length right. Your suggestion to use two knobs to also hold the front sounds good too.
Jim
